Question about Daewoo KOG-867T Microwave Oven
Lamp is glowing but no heating is taking place
Flow chart of same model
    Problem Solver:
  • 3 Answers
Could be a blown internal fuse, or a burned wire, you can open it and look yourself, burned wires and fuses are usually easy to spot.
Best to have a repairman check it out if you are not into electronics. Make sure you get an estimate of repairs before you give the ok to fix it, it will most likely be cheaper to replace it due to labor cost,
Posted on Sep 23, 2010
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Emerson 600 Gas Dryer is not heating
1= CHECK your supply gas
2= test any leak
3= see if the c.breaker is tripped and reset
4= test the thermal fuse inside
5= see the interlock switch is open and replace
6= see the flow chart and proceed.
God bless you
Jul 13, 2012 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
When I turn it on, the heating element glows, but there doesn't seem to be any gas flowing through. I checked the valve, and it's open. Does this oven have a pilot light that needs to be lit?
The glow you see is actually the ignitor, it has taken the place of the out-dated pilot light. It is likely that your ignitor is partially burnt out and the safety valve is not opening. A good bake ignitor draws just over 3 amps and the safety valve will not open until it reads this 3 amp draw.
If the glow you see is a dull orange, it is likely that the ignitor is bad.
Apr 15, 2011 | Microwave Ovens
I have a Hamilton Beach 900 watt microwave that will run but will not heat the food
maby it's the magnetron, i need more information, a good way to test the magnetron is to put a small HE-NE lamp in a glass filled with water (HE-NE lamps) are found in any radioshack (La source) store, if the lamp glowes orange it meens the magnetron is good, if it is not glowing then the magnetron is dead, (the magnetron is allmost the price of the oven) it could be a fuse but if you have to change the fuse replace it with the same type (normaly ceramic german type) NOT GLASS
Jan 04, 2011 | Hamilton Beach Microwave Ovens
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Microwave Ovens
Sharp R-930 not heating up to temperature
It may be the thermistor, heating element, etc.
We have the full service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The manual has complete disassembly, test and part replacement info, as well as a very good troubleshooting chart.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Dec 05, 2008 | Sharp R-930AK Convection/Microwave Oven
Daewoo KOG-867T Microwave Oven Logo
65 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
