Question about GE WSXH208A Front Load Washer
Washing machine washes clothes but will not drain out water or spin. The lights just blink and the machine just sets there and will not do anything. I have a GE Frontload washer.
    President:
  • 2,468 Answers
First make sure the pump isn't blocked by an article of clothing that has gotten stuck in the pump,then make sure all drain lines are clear as any blockage or kinked hoses create back pressure and shut down the unit
Posted on Jul 28, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101 .
Oct 10, 2010 | General Electric Clothes Washer Timer Hub...
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
GE WSXH208A Front Load Washer Logo
186 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
