Question about Dryers
E2 is flashing on my whirlpool duet dryer whats this mean
    President:
  • 2,468 Answers
You have a shorted thermistor in the exhaust vent housing and it needs replacing
Posted on Jul 28, 2010
Dryer not working. failure code E2
The electronic control board detected that the thermistor located on the blower housing is shorted (zero resistance). Either the wire harness connecting the thermistor and the electronic control board has a short circuit or the thermistor is indeed shorted. Click on the link below for the detailed troubleshooting instructions of this problem.
Troubleshooting Error Code E2 on Whirlpool Duet Dryers
Mar 01, 2011 | Whirlpool Dryers
My whirlpool duet dryer is giving me an E2 code. What does this mean?
The exhaust thermostat is Faulty and needs to be replaced
Feb 21, 2011 | Whirlpool Dryers
My dryer stops after 15 seconds and the code is E2, what does this mean?
E2 and fast shutdown is a shorted thermistor. The thermistor is mounted on the blower housing right next to the duct fusethemobilian_1226.jpg
Video:
Service manual and more info is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
Code E1
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet Dryer. I keep getting an E2 code. What does that mean?
Not sure but you can go to Google and type in "E2 whirlpool duet dryer" and it should tell you what the code means
Jan 25, 2009 | Dryers
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Marvin
Marvin
