Question about Ovens
Starter takes a long time in oven to ignite help
    Sergeant:
    Champion:
  • 277 Answers
Replace the igniter. It is a simple project that doesn't require a liecences.
Posted on Jul 28, 2010
Takes a long time to get to temperature
If it's a gas oven and has an electric element starter (glows orange to ignite the gas), the element can be taking a long time to heat up, which means the oven doesn't light for a while and so seems to lake a long time warming up. If you turn it on and then look at the area where the flame should be (broiler) and the flame takes a long time this could be the problem. This happened to me and replacing the element fixed it. Now the flames light within 30 second or so.
Nov 11, 2012 | Ovens
One out of every five times or so, the oven takes a long time to heat up, and the smell of gas seems to be stronger at these times as well. Thanks in advance for your help. Chris
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 02, 2010 | Ovens
On the oven, you can hear the gas come on but the oven will not light...the ignition starter?
Sounds like the igniter, Here is a video that shows you how to test it. Scroll down to How to Troubleshoot a gas oven that won't heat.
www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven igniter does not light unless hit
you can check you connections to see if loose wire nut.normaly people will say they hit the oven safty valve and gas will come out.the amp draw on that ignitor is as ive been taught 3.2 to 3.5 if low than that it will have a hard time opening the safty valve.ive sold and installed 100s of ignitors and a few valves.hope that helps.god bless tom
Jan 03, 2009 | Magic Chef 9512 Electric Single Oven
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Automatic Ignition Oven Problem
Depending on the type of ignition used (sometimes they have pressure sensitive switchs other times its just a simple microswitch) the switch's may have gone but also can you hear a clicking but the burners / oven not lighting? if so then the electroeds on the appliance may just need cleaning if not then i would recommend getting an engineer out the repair its self should be pretty cheap
Oct 31, 2006 | Tecnik TKC241/3 Gas Single Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
