Question about HP PSC 2210 All-In-One InkJet Printer
I can't find where I plug the main power cord into the printer?
    Scholar:
  • 35 Answers
Hi hope this helps its an image from HP's website showing where the plug is.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01793528.gif
Posted on Jul 28, 2010
On the power and reset it for 15 sec wait for the green to light up but the green light dont light up . keep lighting orange light keep on light up. pls help
switch off your printer. remove power cord from its main source and remove usb cable connection from printer to computer. wait for 5 minutes then connect back the usb cable to you computer and plug in the power cord ,switch on the printer
Sep 02, 2015 | Office Equipment & Supplies
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
I bought my lexmark at a yard sell but it didn't come with the cords and I like to know what kind of cords I need to get it working it's a all-in-one. Thank you
Hello, Since the specific model of the printer is listed, you will need to search for the parts you need HERE, In general terms, you should have the main power cord which plugs into the wall and most likeky a USB printer cable to attach to the computer. A USB printer cable can be purchased at any Computer store, the main power cable, would most likely have to be purchased direct form Lexmark....
I hope this and been of assistance, Regards.....
Jan 16, 2011 | Office Equipment & Supplies
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
Will not turn on even tho plugged in
Try a different power cord or test the power cord on a different piece of equipment.
If it still does not work then the printer has a power supply problem and needs to be repaired or scrapped. A new printer may be a better cost effective solution.
Unless you have electrical knowledge I suggest you do not try to fix mains powered equipment. Mains voltage is dangerous.
Mar 06, 2010 | HP LaserJet 2605dn Printer
I have a Xerox WorkCentre Pro 412 and it will not power up.
First and most simple. Plug something else into the outlet to make sure it works. If this model has a removable power cord then try re-inserting the cord. While you are there and with the cord installed, lift up then push down slightly and see if it comes on. If the power cord is removable the receptacle where it plugs in are notorious for breaking the solder connections. If this is the case it just needs to be re-soldered. If the outlet is ok, the cord is ok or hard wired in then you may have either a blown main fuse or a bad power supply.
Good Luck
Nov 30, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Regards,
Ed
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Stopped working...is it a fuse wrapped around the power cord that could be faulty?
no that is a graphite ferrol just to cut down noise it may receive from other devices. check the voltage with a meter on the power supply. If it plugs direct into a/c from the wall, the power board is most likely bad in printer. then it's a throw away.
Oct 22, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ricoh Aficio 2232c printer without power. Need to
The main fuse is close to where the cord plugs into the machine. You can follow the wires, (black white and green) to an inline fuse or the main power board.
Sep 22, 2009 | Ricoh Aficio 2232C Color Copier
Both the orange and the green lights are blinking and printer will not print.
The printer is waiting to receive a document to print. Choose the print command from the software program that you are using.
Wait for the printer to complete the current task.
OR
If the printer continues to blink after several seconds, follow these steps:
    1. Turn the printer off, and then turn it back on.
    2. If it does not turn off, unplug the power cord from the back of the printer.
    3. Unplug the power cord from the power source. Wait 30 seconds.
    4. Plug the power cord into the back of the printer.
    5. Plug the power cord into the power source.
  • Restart the computer and the printer. Try printing again.
  • Make sure there is a direct connection from the printer to the computer. Remove scanners, switchboxes, and so on.
  • Try another cable.
  • Try connecting the printer to another computer. If the printer prints, then the problem was with the main computer, possibly a software or device conflict
Aug 11, 2009 | HP DeskJet 5550 InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
