Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
The error code is F 11 - Kenmore 3.8 cu. ft. HE3 Front Load Washer
    President:
  • 1,382 Answers
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08.
Thank you !!
Posted on Jul 28, 2010
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
Code P0171
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 21, 2012 | 2004 Lincoln Navigator
What is code p1330
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 15, 2012 | 2001 Volvo S80
OBD II code PO100
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 04, 2012 | 1997 Nissan Pickup
Ligth
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 01, 2012 | 2001 Chevrolet Tracker
Obd2 code p0171
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Jan 28, 2012 | 2004 Ford Focus
Message d'erreur code 11:11
Error code indicating that Trailing cable faulty, replace it. But technical skills required to replace this spare..
Dec 14, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
Error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Nov 17, 2007 | Pioneer GPS AVIC-X1 car radio
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
