Question about E-Machines AAFQ50400000K0 Keyboard
Can not get the @ to appear when typing on a E725 there are other characters in red on the key and they are coming up when shift is used
    Problem Solver:
  • 9 Answers
Go to control panel / regional and language / language / then add your countrys language then delete the other language. save and restart computer ti should be back to normal now.
Posted on Jul 28, 2010
Testimonial: "Thanks for your help"
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Oct 06, 2009 | ASUS 90-A4C1K1000 Keyboard
How do i make a character that looks like a 7 but vertical portion is straight
The answer is ALT + 191
To obtain an ALT Character:
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear
Found here... http://www.tedmontgomery.com/tutorial/altchrc.html
You will find all the special characters there.
Thanks,
John C.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
Feb 27, 2009 | Dell Inspiron 500m Notebook
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
Computers & Internet Logo
223 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
