SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
SOURCE: Canon PIXMA MP130 'waste ink absorber' message
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
SOURCE: waste ink absorber is almost full,so printer has
Hi there
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1. You will include printer.
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
3. Into the service regime
4. Select NVRAM ACCESS and further BY OK.
5. Select SET Abs- m level and advance value equal to zero.
6. Select SET Abs- r level (if there is) and also you will establish into zero
7. You will turn off printer by button POWER
Some time of other you will need to clean out the inkpads that are in the printer or it will in time leak the ink out.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
