Question about Brother DCP 130C All-In-One InkJet Printer
The printers message says cannot detect cyan ink. What does this mean
    Scholar:
  • 35 Answers
Not to state the obvious but exactly what it says, for some reason the printer is not able to detect the Cyan (Blue) color cartridge in the printer, open the cover on the printer as you would to replace the cartridges, remove the blue one and refit it just incase its not sitting correctly in its holder. also check any metal contacts on the cartridge to make sure there is no dirt on them.
if this does not solve the problem i would consider the cartridge to be fautly and look at replacing it with another one.
Posted on Jul 28, 2010
5 Suggested Answers
  • 54 Answers
SOURCE: put new ink in printer l7590 message comes up
1. Check the cartridge number is same as the L7590
2. If same, by replacing the new other ink cartridges
3. if the issue persists, then perform the below steps.
Unplug the power cord from the HP All-in-One.
Wait for 20 seconds.
Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
Release the buttons after the HP All-in-One starts up.
The HP All-in-One will now be reset to factory defaults.
4. if the issue persists, then follow the below instructions.
It should resolve the issue.
Posted on Sep 03, 2009
  • 17 Answers
SOURCE: the printer has ink in the chambers, but message keeps coming up
Ink sticks are blocked in the ink loader assembly.
Are using generic ink sticks "Media Sciences" perhaps?
Remove all ink sticks and reinstall.
Posted on Aug 21, 2009
  • 44 Answers
SOURCE: Printer will not ''see'' Cyan Ink Cartridge...
Call Cannon there might be a firmware update for your printer or buy another printer.
Posted on Sep 12, 2009
  • 979 Answers
SOURCE: I have problem with my HP business ink jet 2230.
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Posted on Sep 16, 2010
Install cyan
That message is saying you need to replace the blue "Cyan" ink cartridge in the printer. When the printer detects that the ink in out it tells you to replace the empty one to continue printing. Just buy a new cartridge install it and you will be good to go.
Jun 29, 2013 | Brother MFC 210C All-In-One InkJet Printer
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
I am getting a message "CM Ink Empty" can you advise what this means please
Hi there!
The message CM ink empty means that the cyan/blue and magenta/pink ink cartridges are empty and needs to be replace.
Hope this helps. Thanks
Mar 31, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
Sep 16, 2010 | HP Business Inkjet 2230 Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
I haxe recently purchased a brand new canon mp530 that is still under warranty.I don't allways have the problem but often enough for it to be one.Adout 90% of the times I try to print I get an error...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
Soruce: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Brother DCP 130C All-In-One InkJet Printer Logo
653 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
