Question about Watts Onan Portable Generator - 4000 , Model# 5500
My Power Pro model 5500 runs fine, but gasoline leaks from the fuel filter. Any Ideas?
  • gfgordon Jul 28, 2010
    The email response to me stated: "A new solution has been posted for your Watts Onan Portable Generator - 4000 , Model# 5500 Problem on FixYa.com." However, I assume the answer for Watts Onan whoud be the same for Power Pro.
  • 553 Answers
You most likely either have a crack in the filter or your fuel line has started to harden and is no longer sealing. The best solution is to replace both the filter, lines and be sure to replace the clamps if they are the spring type.
Posted on Jul 28, 2010
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
My power pro 5500 running bad unless I hold butterfly on carb open
Sounds like dirt or varnish in the carb. You will have to take the carb apart and use some carb cleaner. Spray it in and be sure to wipe it down. This most probably happened because you stored the gasoline in the generator tank without adding a good gasoline staybilizer if your going to store it for a long period of time. I usually flush out all of the gasoline whenever I finish using mine. Here is a tip.. Once you finish using your generator then drain out the gasoline then keep trying to start it up again. Once it starts just let it run out of fuel. This gets everything out of the lines and the carb.
Good luck,
Marty
Good luck,
Marty
Jul 16, 2014 | Electrical Supplies
2.5 liter no power
Check for back pressure in the exhaust. A plugged cat will cause the exact symptom you have described.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 07, 2012 | 1987 Jeep Comanche
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Aug 23, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Gasoline in mixed with oil in the crankcase also oil pouring out from the valve cover. Runs rough and smokes badly. What are the possible causes?
Gasoline in the oil is indication of fuel leaking past the needle and seat when the engine is not running (also high pressure in the fuel tank). You may be able to continue to use the generator with weak needle and seat (change oil) , however you must shut off the fuel when the engine is off. Easy fix however by installing carb kit. Find model number of the engine (stamped on fan cover) and contact small engine repair shop or look on line. Do not run the engine with gas in oil. Good luck.
Jul 29, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
My WEN 550 generator has spark, but won't run. I have used some started fluid and it will run a couple of seconds only. I took the carb. apart and cleaned the needle valve, this did not do any good. Still...
I suspect that your carburetor is gummed up by the alcohol laced fuel that you are forced to use. If you leave that fuel in your machine for 3 months or longer. the alcohol absorbs water that will form a jelly like gunk that will clog all of the ports as well as your fuel filter. What happens is the alcohol evaporates and leaves behind the water that mixes with the other additives in gasoline. You are going to have to clean your carb, and fuel filter. Drain all of the old gasoline out. Put fresh in and mix a little SeaFoam or other gasoline additive. The SeaFoam will help dissolve the gunk, and maybe you can get it started to run to see if it will clean itself out. You may still have to dismantle the carb and clean. At the end of the use, drain all of the gasoline out of the tank and leave it dry for storage.
Feb 05, 2011 | Watts Onan Portable Generator - 4000 ,...
COLEMAN 5500 GENERATOR. IVE HAD IT 3 YEARS,
Gasoline goes stale after sitting a while and makes starting hard. Three years worth, it's more like jelly! You need to clean the tank, lines, filter, and carburetor. Run it for a while on a little fresh fuel after cleaning, then let it run out of fuel. That will remove most of the fuel from the carburetor. When you want to run it again, add whatever fuel you need, but allow it to run dry again. That's not prefect, but workable.
Aug 19, 2009 | Electrical Supplies
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Good carb, just runnin way too rich
On the carb you should have 2 screws. One for the air and one for the fuel. You will able to adjust your air fuel mixture via those screws.
Jun 24, 2009 | 1983 Ford Bronco
New MasterCut mower runs erratic & gasoline leak around fuel cap.
as it is a new machine if it has not been p.d.id by dealer it may be that some test fuel residue is in carburettor which is causing this,you need do drain of carburettor of all fuel,remove bowl and spray clean useing either air or carb cleaner spray(should get from local autoparts store) note try to spray up centre of carb as may be a jet up there as well,refitt bowl and make sure you use fresh fuel this should solve problem,with unstable running fuel may be finding a way back through breather at carb with the vibration and may be cured after you have done carb
Mar 28, 2009 | Garden
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
122 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
