Question about Microsoft Windows XP Professional
How to assemble a cpu of an window xp computer
    Problem Solver:
  • 9 Answers
You can assemble P4, celeron, athlon, and dual core with compatible mother board.
If you need to configer latest CPU then follow this link.... http://bit.ly/bbOrc0
Posted on Sep 20, 2010
  • 148 Answers
Please do as this
Thnks
Posted on Jul 28, 2010
Sir i m using windows 7 ultimate...n i want install tally 7.2. i cant use it in windows 7. i m also trying run as administrator, change compatibility mode in windows xp sp2 mode...but i hve same probs..so...
Tally 7.2 is not longer supported. You might need to upgrade to the newest version.
The only other suggestion is to see if you can run in XP Mode. This will depend upon your computer requirements.
Running Windows XP Mode requires:
1. Windows 7 Professional, Enterprise, or Ultimate editions.
2. A computer capable of hardware virtualization. This means your computer has a central processing unit (CPU) with either Intel-VT or AMD-V virtualization features.
3. Virtualization features turned on in your computer's basic input/output system (BIOS).
To determine whether your computer's CPU is capable of hardware virtualization, go to the Windows XP Mode and Windows Virtual PC support website and download a utility that can check whether your Intel or AMD CPU is compatible.
http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
To find your brand of processor so you can download the appropriate utility, click the Start button , right-click Computer, and then click Properties. Under System, next to Processor, you can see what type of CPU you have.
Even if your CPU can run Windows XP Mode, you might also need to turn on virtualization settings in your computer's BIOS. Procedures vary depending on the BIOS manufacturer. For more information, see BIOS: frequently asked questions.
http://windows.microsoft.com/en-us/windows7/BIOS-frequently-asked-questions
For more information, please logon to:
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7#section_3
Regards
Riztech
May 22, 2011 | HP Pavilion dv6000z Notebook
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
Cpu problem?
i think maybe your pc atacced by virus ! format your hard driver!
Oct 11, 2009 | Microsoft Windows XP Professional
Problem installing OS in a newly assembled PC
Try installing first the windows xp.Make two apartments and install the Xp on the one.The other one format it,boot with the linux cd and try to install it to the empty apartment.Be sure that your system supports the linux kernel because some of the CPU brands don't support the linux OS;S.
Good Luck
Jun 23, 2009 | Computers & Internet
I just installed xp pro and it keeps freezing
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Slow computer
Pro won't make it run faster. Make sure the processor is fast enough to handle XP. If it's an older computer you've upgraded to XP, it may not have the horsepower.
Read this page from Microsoft:
http://support.microsoft.com/kb/314865
If the CPU conforms, the best thing to do is add RAM. I recommend a minimum of 1 GB for XP machines.
Make sure the hard drive is not nearly full, as that will limit the paging file that Windows uses. If your drive is near capacity (+90% full) it will slow down any computer, regardless of how much memory you have, or what speed the CPU is.
Jul 17, 2008 | Computers & Internet
Buy A CPU
Most used computer stores will have Windows XP installed on their computers. They often have a warranty just in case. The other way is to look in local newspapers under classified.
Nov 03, 2007 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional Logo
75 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
