Question about Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010
1984 B&D double sided hedge trimer stops and
B&D double sided hedge trimer stops and occasionally starts when tilted-I've opened it but no obvious loose wires- is there a common problem or obvious answer please ie can I fix it!
Thank you
Model GC400G /H5 405MN
No 1000 1600/MIN
240V -50HZ 1.8A 400W
S4D09
1984
  • T100 Dec 03, 2010
    same happened twice over the years with mine-its 25 years old and I cut the plug off (as they are sealed) and put a new one on-solved the problem in both cases
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
Posted on Jul 31, 2010
Testimonial: "hey - that gives me hope anyway and I'll try and see if thats the answer-cheers my friend! "
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
Installed new throttle cable on 225h60 trimer but need pic of connedtioon @ carb. to finish assm.
Post a picture of what you're looking at. I own a 225h75 and can tell you once I see it and can describe it to you using your picture.
Oct 01, 2013 | Husqvarna 225h60 / H75 Hedge Trimmer Owner...
My Black&Deck 24" Hedge trimmer simply stop working. There is no action what so ever when I turn it on. Any suggestion? Do I need to locate and change the fuse? Thank you!
Check the black and white power wires to the motor. You will have to open the trimmer casing. I have 2, 18 inch B&D hedge trimmers and both of them stopped working due to wires coming loose at the motor. I re-soldered the wires to the motor and both trimmers work fine.
Jun 26, 2010 | Tanaka 30" Double Sided 24cc Hedge Trimmer
Homelite trimer 18.0v charger, battery, yellow
homelite 18.0v battery charger, yellow amd green light on,won't charge,lost manual.
Sep 12, 2009 | Homelite Garden
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
How do I sharpen my trimmer
WITH A FILE FRONT REAR ON BOTH SIDES.
POSITION BLADE BY ROTATING MOTOR FAN.
Jun 14, 2009 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
192 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
