Question about LG (GDR8164B) Internal DVD Drive
My lg drive is not reading disc but it is detecting in system
  • 3,940 Answers
No power on
Try connect it to other PC.Inspect the connectors inside the PC.
The drive doesn't have power.
• Is the power supply cable from the host computer plugged in?
• Is the Power Connector to the drive securely attached?
• The system doesn't start.
• Are the Primary and Secondary connections and the Master and Slave settings
correct?
• Is the total length of the IDE cable 18 inches or less?
• Is each connector completely attached?
Other connections may have been knocked lose while installing the drive.
• Cannot Read or Write Discs.
• Is the condition of everything else in the system (CPU, hard disc, and others)
as it should be? (See system environment page 2.)
• Does the CD or DVD disc have dirt or scratches?
• Did a screen saver or other application operate while writing to the disc?
• Is there enough free space on the CD, DVD and DVD-RAM disc?
• Does writing fail even using the simulation test?
• Is the disc loaded in the drive with the read/write surface facing the right
direction? (label up)
• Is the drive installed in the correct orientation?
• Was the drive or disc moved from a low temperature environment to a high
temperature environment? (There is a possibility of condensation on the lens in
the drive or on the surface of the disc.)
• Using a 40-pin IDE cable might bring the '04/08/03 error (LOGICAL UNIT
COMMUNICATION CRC ERROR (ULTRA-DMA/32))'.
In this case, substitute to 80-pin type IDE cable is highly recommended.
This kind of error is hardly detected from some specific motherboard
Dec 12, 2010 | LG GH22LP20 DVDRAM Burner
My LG portable dvd drive detects discs but doesnt read them.It started today and also mekes noise even when there is no disk
You should clean you drive head.. you may use a cd-cleaner to do this and if problem persists, then your lens is spoilt.
Nov 20, 2010 | LG GP08NU40 Super Multi Disk drive DVD...
Does not read burnt discs? how do I fix it
It may the problem of lense inside DVDRW which helps to read the cd if the lense get spoilt the DVDRW wont detect burnt discs
Aug 19, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Does it play cd and dvds
You can only play CDs of all kinds (CD +/- R, cdrw, etc.) but you will not be able to play any DVDs. It will not detect any DVD disc.
Jun 23, 2010 | LG CRD 8400B (CRD-8400) Internal 40x...
Free download for lg dvd drivers gh22np20
I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing LG drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Mar 13, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
LG DVD recorder no longer detects any discs in the drive
do one thing change the Bus cable of lg dvd writer, then check if the problem persists check the drive on some other system, if the result is the same the fault is in the drive
Sep 17, 2009 | LG (GSA-4166B) (GSA4166BB) DVD RW Dual...
Do not read the cd or dvd disc.
Its zamzam,i wud suggest you buy a new one from a better manufactuerer.
Aug 19, 2008 | Computers & Internet
Problem in running dvds
are you sure it reads dvd's ? If it does it should have a dvd logo.
If thats not it Laser may not be working correctly and you will probably need to replace disc drive.
nowadays you can find them real cheap and are easy to install.
Feb 24, 2008 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
LG (GDR8164B) Internal DVD Drive Logo
75 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
