Question about Weather King 10AJA6001AH Air Conditioner
Fan not moving - Weather King 10AJA6001AH Air Conditioner
    President:
  • 2,468 Answers
First,with power off,try to manually turn the fan by hand,it should turn freely and coast to a stop by itself,then if so,there is what they call a "dual-Capacitor" inside the unit and one side of this capacitor is the motor start/run capacitor and they go bad,it is a silver can with 3 terminals marked F/C/H fan/common/hermetics (for the compressor), and will say something like 5uf./35uf at 440 volts A.C. on the body of this component go get a replacement at most electrical outlets
Posted on Jul 28, 2010
Exhaust fan is hitting something while running
The fan blade shifted (moved) on the motor shaft. Take it apart (usually from the rear) and move the fan blade a 1/4 to 1/2 of an inch to clear the housing. Don't add oil to the shaft otherwise it will move again.
Jun 25, 2013 | GE Ovens
Motor seems to be working but fan does not turn.
NEED MORE INFO!!! Make/model of fan would be nice!
Mar 18, 2013 | Dryers
Testing a fan model number 80855bqva-a25
The fan is faulty, could have seized bearing.
Feb 11, 2013 | Computers & Internet
When trailblazer is on, i hear a loud squeeking sound. when checking engine i noticed that the radiator cooling fan and pulley move up and down. does not seem to be wobbling at all just moving up and down....
Sounds like your fan clutch is going bad. If you can move the fan by hand then I recommend changing the fan clutch. If it completely fails your fan will be shot through your radiator.
Apr 22, 2010 | 2004 Chevrolet TrailBlazer
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
Ceiling fan wont move much air even on high speed
shut off fan, wait until it comes to a complete stop. switch button on base to other position. turn on
Sep 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
My 2004 Montero Sport blows cold air when I am moving but only cool air when not moving. The pressure looks good on the a/c, about 35psi at 70 degrees ambient temp. There is an electric fan in front of the...
This fan is more tham likely the a/c fan. the reason you only get cold air when moving is bcus air is rapidly flowing over the condensor when the car is moving. when at a stop the fan should compensate for the lack of air flow. This is most likely the place to start, the fan circuit and components.
Aug 10, 2009 | 2004 Mitsubishi Montero Sport
Whole house fan does not draw air
capacitor is worned out so pl change the condensor and u ll find the difference out lot of air moving around u
Jul 28, 2008 | Ventamatic Direct Drive Whole House Fan...
Weather King 10AJA6001AH Air Conditioner Logo
125 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
