Question about Refrigerators
Not making ice cubes. Water comes out from door, but is not making ice cubes
    President:
  • 1,099 Answers
Maybe the icemaker got accidentally turned off. Look for a switch inside the freezer
Good luck...
Posted on Jul 28, 2010
Samsung French door ice maker
Sounds like you are getting to much water or the sensor is not Sensing proper temp
Apr 02, 2016 | Samsung Refrigerators
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
