Question about MTX Thunder 4250D Car Audio Amplifier
Not a green light comes on like normally... a yellow one comes oh
I start my car and the yellow warning light appears on the amp.... not aloowing it to work
  • 70 Answers
Could be the wires is bad or someplace the power wire is grounding out or the fuse or fuses is blown. or could be not enough voltage but highly doubt it.
Posted on Aug 03, 2010
Is it normal to have a red triangular warning light come on after pressing the start button and then go off as soon as the other lights(car seat, air bag, break etc) go off..
It's normal. It's part of the instrument cluster module doing what's called a "bulb check" on initial start up, and it should go off in under ten seconds, since it does, there is no problem
Feb 17, 2015 | 2015 Toyota 4Runner
Why does the Engine Warning light come up but other warning lights like battery, oil pressure etc.don't show up in ignition mode & the car doesn't start?
Sounds like a wire was not re-installed under the hood. When the alternator or battery were replaced, there are several power wires under the hood that attach to the same power terminal. Look for a RED wire with a large round connector, that is just hanging out in the open air. You need to install it back onto the post that it came off of. good luck.
May 07, 2014 | 2010 Chevrolet Spark 1.2
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had...
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
Nov 25, 2013 | 1993 GMC Sierra
Hit a bump on the road and the engine cuts out. No warning, no warning lights. Engine starts normally after that.
Check to see that your battery is secured. See if you can wiggle it. Make sure all battery terminal connections are tight, and all ground wires.
Mar 03, 2013 | 2000 Volkswagen Jetta TDI
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
Warning Lights
Are your hazards lights on? I don't know your car but The triangle most of the time is hazards lights. Now when you turn your key on all the light should come on then go off, If on stays on in some cases it could be just a bulb. To check your Bulbs use you turn singles / blinkers. You can get them on by turning key to on with out starting car. Then turn on our left by pushing switch down first. Check driver side front & rear. Then check passenger side by switching to the right switch up. Good luck
May 17, 2010 | 1994 BMW 3 Series
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Sanyo PRO xtraX Multimedia Projector Mod.# PLC-XP1ONA
this is the normal condition> only when green led is off and warning temp led(yellow) is on something is wrong!!
Jun 08, 2008 | Sanyo PLC XU35 Multimedia Projector
MTX Thunder 4250D Car Audio Amplifier Logo
46 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
