Question about Panasonic PT L750E Multimedia Projector
Need owner's manual
How can i get lamp replacement for Panasonic multi-media Projector PT-L750E
  • 906 Answers
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Opokuagyeman,
Suggest that you consult the Panasonic Support Team for your lamp replacement.
Thank you.
Posted on Jul 28, 2010
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Panasonic projector PT-L78 - Cannot get ride of Lamp time error. To reset the timer
How long ago did you replace the lamp?
If the lamp has not actually been replaced and you are attempting to bypass this safety feature then I have bad news for you. Once the projector determines current flow through the lamp has exceeded the threshold amount, it will put the projector into the mode it is in now - Critical Lamp Replacement. You can set the projector bulb to low power output and see if that allows you to reset the bulb life timer but, again, if you have not actually replaced the bulb assembly, you are in danger of the bulb bursting under pressure. This can actually damage the projector.
You can find the manual for your projector at
ftp://ftp.panasonic.com/projector/ptl785u/pt-l785u_oi.pdf
Nov 01, 2017 | Panasonic PT-L785U Multimedia Projector
I need a new ballast for my Panasonic ptl735u projector
www.yylamp.com
I am Maggie from Yue Yu Electronic and I am in charge of the export business.
We, specialized in multi-media projector system engineering and maintenance service, wholesale and retail all brand projectors and its accessories (lamps, ballasts, polarizer, light tunnels, filters, burners, main boards, LCD panels, color wheels, lens, remote controls, etc.), have exported projector parts for many years.
If you need any projector parts, do not hesitate to contact me.
Email address: Maggie2010great@yahoo.cn
www.yylamp.com
Aug 15, 2011 | Panasonic PT L735U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
PT-D5600U DLP Projector: Our projector was working last week no problem, bu...
Hello!
Replace the lamp assembly with OEM only! After you pull the old one and carefully install the new, you must reset your unit. The procedure should be supplied with your new lamp. Or, refer to owner's manual. Most likely, it will be inside of your new lap's box. Make sure, read it and keep in a safe place, after all. Next time you may buy "generic" lamp, but you will know how to reset.
Good luck,
Alex.
May 12, 2010 | Panasonic PT-D5600U DLP Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
How do you reset lamp hours back to zero on a Panasonic PT-D4000U projector?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Apr 13, 2009 | Panasonic PT-D4000U Projector
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Panasonic PT L750E Multimedia Projector Logo
59 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
