Question about Mizco CELLULAR INNOVATIONS HFBLUCK2 Slimline Bluetooth(R) Speakerphone
How do you reconnect with the HFBLU-CK2 bluetooth after you come within range? The bluetooth is left on when I leave the car, but when I return I need to know what to do to reconnect.
    President:
  • 567 Answers
Hi there you can try these steps: So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Posted on Jul 29, 2010
  • 2 more comments
  • Hilton Bristol Jul 29, 2010
  • Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
    By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
    On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
  • Step 3On your handset, find the bluetooth menu.
    On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
    On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
    Nokia Phones: look for "search for new audio enhancements". Hit OK.
    On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
  • The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
    Either way, select it, and hit OK.
  • Step 5The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
    Enter these four zeros and select "OK"
  • Step 6The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
    "Connected to headset".
    At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
  • Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
    Keep in mind that when a call comes in, the phone will still ring like normal.
    You can answer the call by either:
    1. Pulling the phone out of your pocket and hitting the answer button.
    2. Touching the answer/end button on your headset without reaching for you phone.
    The range of your headset is up to 30 feet, in a direct line of sight.
    If you go into another room, your range may be decreased.
    If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
  • Step 8If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
    *** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
    I hope this solve the problem.
    sorry i mean to post this to someone else so its a mistake.
    I put my HFBLU-LT200 bluetooth headset on charger and both blue and red light have turned on permanently. Bluetooth has stopped working
    That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
    Feb 04, 2010 | Cellular Innovations HFBLU-AX1 Bluetooth...
    I need a new manual for model number hfblu-1k where can i download one?
    This product is very frustrating. I also need a pin which I don't have and it originally worked just fine with my Blackberry without any PIN.
    Cannot get anyone at MIZ to answer the phone or return a call. I've called their support number 1 800 266 4026 but cannot reach a person.
    Nov 05, 2009 | Cellular Innovations HFBLU-AX1 Bluetooth...
    I have misplaced the information on how to work my bluetooth headset (HFBLU-1K) could you send me a new one Thanks
    Hi
    These instructions should work for pairing your bluetooth device
    1. First turn OFF the Bluetooth Headset
    2. Place the Headset within a distance of 1 Foot of your phone.
    3. Hold down the power key for about 8 seconds until indicator light blinks and starts to alternate between red and blue. This shows it is in pairing mode
    4. Set your phone to search for a bluetooth device.
    5. Select HFBLU-1K in the bluetooth device list and if required enter the password 1234
    Hope this helps. Do let me know how you get on and remember to rate my answer. Thanks.
    Oct 02, 2009 | Cellular Innovations Cell Phones
    PAIRING MY BLUETOOTH
    Bluetooth headsets are the most common cell phone accessory and quickly have become a common sight when out in public. Everyone from teenagers to businessmen are wearing bluetooth headsets, seemingly talking to themselves, and carrying on in their day-to-day lives. Over the last two years, the popularity of bluetooth has made wireless communication a part of everyone's lives and while owning a headset used to be out of the price range of many cell phone users, that is no longer the case. Now, more than ever, cell phone users everywhere are investing in bluetooth headsets and using them when making and taking calls.
    Nov 24, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
    Need a users guide (instructions)
    For Cellular Innovations Mini Blue HFBLU-AX1C.
    To Pair with Your Phone....
    1. Turn OFF Bluetooth Headset
    2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
    3. Search bluetooth device through your mobile phone.
    4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
    Jun 12, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
    BT pairing code
    Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
    Plantronics bluetooth model# HFBLU-CX1
    how long have you had them and if it's less than 30 days exchange them i sold plantronics and had alot of returns every day so.....
    Oct 06, 2007 | Cellular Innovations HFBLU-CX1 Wireless...
    Mizco CELLULAR INNOVATIONS HFBLUCK2 Slimline Bluetooth(R) Speakerphone Logo
    401 people viewed this question
    Top Mizco Cell Phones Experts
    Marvin
    Marvin
    William Alequin
    Are you a Mizco Cell Phone Expert? Answer questions, earn points and help others
