Question about Maytag MTB1976HR Top Freezer Refrigerator
Our Maytag MTB1976HRW leaks water under the crisper drawer. The drain has stopped up before but if this is the problem how do we solve this without having to call a repair person?
    President:
  • 1,099 Answers
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Hope this helpout......
Posted on Jul 28, 2010
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water under crisper drawers
I am pretty sure you are having a defrost drain blockage problem. Most refrigerators defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section (depending on the style refrigerator you have).Click Here=> Leaking Refrigerators Just What may Be Happening
Much more on this page=> Leaking Refrigerators!
I willbe here should you have questions, Thank You,
Sea Breeze
Feb 08, 2012 | Maytag Refrigerators
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking
you need to remove the back and if lower panel in freezer is removeable, take both out and under the evap in back the drain is stopped up / clear with hot water / will be ok after that
Nov 26, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
We have water under our crispers in our white-westinghouse refrigerator. How can we fix this?
You have a stopped up drain. The drain is located in the bottom of the back of the freezer. Go in thru the inside of the freezer, remove the back panel and you will see the small opening in the back bottom. It will be frozen up with ice also. Defrost the ice off the drain and try to get hot water to pour down the drain until the drain is clear. I use a flexable piece of hose to blow through the drain until the clog is gone. This will eliminate the water leaking down under the crisper drawers. Good luck and I hope this will FixYa.
Mike
Sep 24, 2008 | Refrigerators
Maytag MTB1976HR Top Freezer Refrigerator Logo
274 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
