Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
My frigidaire stopped making ice - Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
    Novelist:
    Champion:
  • 266 Answers
Inside the fzr on the side of the icemaker is a metal wire arm that needs to be down and not raised. (down on raised off) If you manually put water in the tray and the next day the ice is in the bottom your water valve may be bad it is located on the back bottom of fridge where the water line hooks up. Also make sure the motor in the back is not jammed if you have a door ice/water selection. If none of these replace the unit they are held on by two screws and a multiwire plug and they are not exspensive.
Posted on Aug 12, 2010
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Frigidaire Refrigerators
Frigidaire Superba Ice Maker not stopping making ice
-Turn the ice maker off. If still leaking and decide not to use the ice maker to make any more ice then unplug the
water valve that let water run to the ice tray. Only the one for the ice. Otherwise you will not have any water at all.
Good luck
Mai
Mai
Nov 01, 2017 | Frigidaire Refrigerators
Frigidaire Side by Side Ice Maker Not Working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
980
May 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26ZNHD2-ice maker stopped making ice called Frigidaires 800# they told me to replace the 2 stage water valve did that still no water to ice maker
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Ice maker stop making ice
Check to make sure the the little lever that tells the fridge "ice bucket is full" is not frozen or stuck.
Jul 08, 2009 | Frigidaire PLHS237ZD Stainless Steel Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
114 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
