What is meaning of error motor shortening in wascomat washer
I have error in screen ''shortening motor''
please help me
Change the inverter
Posted on Jan 22, 2011
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
Wascomat w655s what is error code E13 ?
www.teetersproducts.com/.../Used%20Equipment/.../Wascomat%20-%20...
Jul 13, 2014 | Wascomat Parts Wascomat 973957 Washer...
Wascomat W-125
Search craigslist, ebay, and google the part number to try and find a used replacement part. Search for refurbished electronic control boards companies online.
Feb 07, 2014 | Wascomat Parts Wascomat 990251...
Wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Feb 06, 2014 | Dryers
Wascomat 16n4 front of drawer broke off. how can
I have a Wascomat W655CO,
This morning I got a screen message, Wait doors is locked?
I waited but the door never unlocked?
Oct 26, 2013 | Wascomat Parts Washing Machines
Wa50t54w1 elba
this can be a motor control fault, and sometimes a fault with the motor itself, test motor windings for equal resistance, and check motor physically for wear / damage. replace motor controller.
Oct 24, 2013 | Fisher and Paykel IWL12 Top Load Washer
Got a exsm680cl washer and it reads error drain not draining
Check the leveling of the machine, if not use a spirit level and use rubber sheets to keep it firm. If the drain hose is detached the water must freely flow out in this case. If not adjust the slope.
Also check the drain pump to open and work with good action. If not you need to remove and clean the filter and reset the pump
Jan 21, 2013 | Wascomat Parts Wascomat 432 251902 Washer...
Open Questions:
Washing Machines Logo
429 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
