Question about Sharp AR-M455N Copier
My copies are not very dark
I replaced the toner yesterday and have adjusted the exposure and the copies are still light.
    President:
  • 2,072 Answers
Is the problem only with copies? Does the machine also print light?
If is it copy only, remove the glass and clean the lamp and mirrors in the scanner.
If it is both copy and print, then you should clean the laser shield glass and replace the developer.
Posted on Jul 28, 2010
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Canon NP 7130 F copier Copies are dark in some areas and light in other areas. We no longer have a service agreement on this machine. I cleaned the feeding roller in the ADF, new toner in machine,...
Enter in service mode and do an cartridge adjustment. Maybe the toner is not uniformly distributed in cartridge. Also you can search on internet for service manual, this may help you a lot.
All the best !
Dec 03, 2017 | Canon NP 7130 Black and White Copier
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Toshiba 2060 Photocopier prints copies that are a bit too dark.
restart the copier while holding down the "0" and "5" keys. you will now be in service mode. enter "5" and press "start" key a number should show up in the display. this is the exposure value - how dark or light the copies will be. 5 is the automatic exposure setting. around 128 is the normal value. the larger this value the lighter the copies are - the smaller the value the darker the copies.
Enter a new number (exposure value) and press the "interupt" key to save the value. Restart the copier and check what the copies look like. Keep adjusting until it looks good/better.
Mar 26, 2009 | Toshiba 6560 Copier
FP 4080
Hello Bob,
Where are you located? You should be able to find the toner for this machine. Have you tried www.precisionroller.com ?
I am almost positive that they carry the toner and also consumable part as well as replacement parts.
One of the reasons the copies might be dirty, is that the optics, charge wires, cleaning blade, drum, and or fuser unit might need some parts replaced. Without seeing a copy of what the machine is actually doing, or looking at the machine, it's hard to pin point exactly what is going on.
If you have any questions with the machine, feel free to post any questions and I will be glad to help you.
Good luck.
Hope this helps.
Mac =)
Feb 29, 2008 | Panasonic FP-7735 Black and White Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
Sharp AR-M455N Copier Logo
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
