Question about Kenmore 22442 Top Load Washer
My 2 yr old kenmore washing machine overflowed the water did not stop filling the tub until I stop the machine. When I open the machine the tub was almost full of water. Put the machine to spin cycle, water in the tub drained properly. Plumber turned on the machine and run a test to wash, the machine did not overfow. Please advise why the machine overflowed and when test was done to wash again the machine did not overflowed.
  • vigeeo Jul 28, 2010
    Sorry, the model number is 417.97922701. I called sears the representaive and gave the model number, asked me which switch I was referring to. I told her water level switch but she could not help me since I don't know anything more than a water level switch. The sears rep indicated that there is more than one switch. Thank you!
    President:
  • 1,218 Answers
Good day,
The only reason that could happen is if the water level switch hung up, at least that time.
The water level switch is in the consule and is connected by a plastic tube to the bottom of the tube. When the washer fills it builds up pressure in that line and causes the switch, which is electrical to switch from filling to agitating.
It may or may not repeat the problem again, at least not soon.
To ease your mind, it may be prudent to replace the switch, since it might occur when your not around the machine, causing a flooding problem.
One trick I learned long ago is o take the model number and call your local appliance parts house and ask how many of that particular switch were sold in the last 90 days.
If it's a commonly sold item then replacing it would be the proper thing to do.
If not, then you'll have to decide whether to wait it out to see what it will do.
However, water can cause a great deal of damage to a house and that should be your deciding factor.
Posted on Jul 28, 2010
  • 2 more comments
    Thank you for your answer. The model of my washing machine is Kenmore 97812, do you get a lot of question regarding this particular model.
  • John Hall Jul 28, 2010
    Good day again,
    Not really a lot of calls. But people with near new machines tend to go to Sears for service.
    You could, but it is a Whirlpool machine, that is why I made the appliance parts house suggestion.
    2 years is not enough time to develop a pattern of specific issues. I wish I could give you more info at this time, but until they have been around longer it is an unknown.
    Again, a sharp counter man at an appliance parts house can put your model up on his computer and see sales on replacement parts sales. They are your best friend at this time. It has to be a parts house that deals in decent volume, to get a decent perspective.
    P.S. That is not a complete model number. It should start with a 3 digit number and a dot, followed by a series of numbers.
    Good day again,
    Yes, it's called many different things. Fill control/switch. water level switch/control ect.
    My advice ws an independent appliance parts house. Just tell them its the control that determine how high the tub fills. An experienced counter man should have no issue with that. All washers have one. Should not be a difficult issue.
Just put all new hoses on y kenmore top loading washer machine went to fill and it almost overflowed no spin or any other cycle working
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Oct 26, 2010 | Kenmore Washing Machines
Machine keeps overflowing during wash cycle
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washing machine, dispite what water level it is set on, keeps filling and filling until it overflows. What is the problem?
Trash and sand is in the bottom of the tub blocking the pressure tube.
Remove the tube from the water level switch and blow through it to get the seddiment out. Replace the tube securely empty any standing water and retry' screw%20removal.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 24, 2009 | Kenmore 22422 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Washing machine
Almost, I hope you put the tube back on. This goes on the pressure switch and the pressure switch determines when the tub is full according to the load size. I don't know what post you read, there's been so many. You have a couple of things to check here. First, make sure the hose going from the pressure switch to the tub is clear. Blow through it. If it's clear it's possible you have a faulty pressure switch. If that tube is not secure on the switch and the tub you will overflow. If the pressure switch is faulty, you can overflow too. Catriver.
Aug 24, 2007 | Kenmore 45081 Front Load Washer / Dryer
Kenmore 22442 Top Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
