Question about Whirlpool ART535 Top Freezer Refrigerator
Model EHT-201ZH Freezer compartment wont get as cold as it used to. It still makes ice but icecream is soft. It is adjusted to max cool. Help!!
  • 145 Answers
Check to see if the condenser is clean. Also that the compresser is getting enough clean air.
Posted on Apr 24, 2008
The freezer is not freezing. My icecream is like soft serve as if it has been sitting out for maybe 10 mins.the icemaker is still making ice but not as fast.it's taking all day to fill the ben when it only...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 14, 2011 | Refrigerators
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active Smart® E522BR...
I just got a G E refrigerator from home depot model # gbscohcxarww. And the freeZer on the bottom works but the ref rig on top doesn't get cold
set dials to middle setting, max cold makes cold freezer, not reefer box!! if freezer makes ice its ok just set to cold which starves reefer box of air. add 2-3 gallons of water to the freezer and or reefer box, if empty it wont cool much.
Nov 01, 2010 | GE Refrigerators
Hopoint fridge freezer model ff78p - fridge is not cooling
check the damper door vent between the freezer/refrigerator compartments and make sure this door is opening and closing as you adjust the cold control in the refrige section,it may have a diverter cover on it but you should feel cold air flow in this area even if its only open part way,then remove this cover and check that its not iced up if so use a hair dryer carefully and deice it,then try the control and see if it opens and closes as you adjust the cold control in the refrige
Mar 27, 2010 | Refrigerators
Freezer is cold, ice bin suddenly melts.
Check for air leaks around the dispenser. Check to see if flap is closing properly. Is the icecream hard? If it is soft, check the conderser coils.
Oct 30, 2009 | Refrigerators
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Whirlpool ART535 Top Freezer Refrigerator Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
