Question about Fisher and Paykel GWL11 Top Load Washer
GW11 washing machine. Water will not drain during rinse cycle
GW11 washing machine. Water will not drain, and I am fairly positive something is blocking the hose. My girlfriend used some sheets that are supposed to replace detergent, and i think it got sucked down the slots underneath. I was able to blow through the hose that drians into the stationary tub, and i got two of the sheets out. Once I got the two sheets out through the slot with needlenos pliers, i ran a quick cycle and the water drined. I then tried to do a load of laundry, and the water did not drain when it came to the rinse cycle. I think there is another sheet there. Is there a way to get down there for sure? The black hose in the back does not appear very easy to detach, but i think it is below where the clothes go into. Any help would be greatly appreciated as i have spent several hours already on this. When the machine doesnt drain it has a constant beep. Any help would be greatly appreciated.
  • 70 Answers
OK what you can do in remove the inner bowl if the machine is full of water this way you can be sure all of the debris is removed, so to do this remove the agitator there is a nut inside and the bottom, then take out the 2 screws in the front under the lid, then lift the whole lid assembly up it should go right back, you might need someone else to hold it, be careful not to break the tabs at the back either, then pull straight up on the inner bowl, it might be a little stiff but it will come out, at this stage now you can bail out some water so you can see what your doing, the in the front right "corner" you will see the top of the pump housing, there is 1 Phillips screw holding the housing down, remove it the housing is in 2 pieces remove both of them and clear out all debris, this is how you clear the pump from the top, Put back together in reverse order. Hope this helps :)
Posted on Jul 31, 2010
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Cycle has stopped 31 mins from end and has lit up check water. No blockage and this should be the drying cycle. Is this a repairable problem or not as it is old?
On many older machines, there was only one water pump. During the wash and rinse cycles, the pump would cause the water to spray the inside of the cabinet. At the end of the cycle a solenoid would open a valve and the pump would then cause the water to be sent to the drain. There are a couple of ways to check for this. Ordinarily, you would hear a knock or thump when the solenoid operates. Another way to tell is if you still have a lot of food particles during the rinse cycle - particles that should have been drained out at the end of the wash cycle.
Some solenoids were not particularly expensive and are fairly easy to replace. If you post your make and model number, I can get more information for you.
Apr 05, 2016 | Dishwashers
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
Jan 14, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
250 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
