Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have the intex salt water system. My water is now a greenish color. I've cleaned the cell and have it set to boost. Do I need to do anything else to get rid of the green water?
  • 297 Answers
You will need to clean the pool completly now.
I am not a great typist so I will copy and paste my solution that I typed out and helped someone else
So many peolpe are led to believe that using a salt system takes away the need of other chemicals
This couldn't be further from the truth A salt system just makes it so that you do not have to physicaly ad liquid chlorine or float tablets
First of all lets get a little educated in pool maintainence 101 and then I will address your problem ( First problem was buying an Intex product ) but I will cover that too
You can not just blindly ad salt to the system
you need to get a salt test kit that reads in #'s not color
You need to get the water to as close to 3000ppm as possible
Any lower than 2700ppm and you can trigger low salt alarm, not to mention not generating enough chlorine
Any higher than 3500 and you can go cloudy, trigger high salt alarm and you could go cloudy
Now for the intex curse
not a single pump/filter is sufficient with the pools they come with
They are to small
A pool needs to be turned over at least 3-4 times in a cycle 24 hours
I do not know your gl or pump size so I will use generic #'s
If you have a 5000gl pool and a 1500gl pump thats 10 1/2 hours of filtering at the minimum
Use your #'s and figure out what you need to be doing
You want to start by getting your salt right this is crucial What it says in the manuals is just a starting point the fine tuning is up to you
Lets now side track and I will tell you how to cure your problem.
This is time consuming but will give you the best results
Blast out your paper cartridge with the water hose now ad 1 gallon ofliquid chlorine
Filter only for 24 hours now brush your pool with a pool brush not the bristles under your vaccum not enough of them to do any good
now clean the filter again and run for a few hours until you see things settle down
Vaccum and clean the filter and start over again
Check your chlorine if it is normal or low ad another 1/2 if it is super high then leave the chlorine step out
Once you are clear again or close to it Ad a non foaming algecide and also ad chlorine stabilizer this is a chemical that you put in a nylon sock and float it behind the ladder this will help hold the chlorine
Once your chlorine level is at the point you can swimm again you should get your best swimmer to get in with a tooth brush and clean the over flaps in the seems that are on the bottom and where the sides connect to the floor
This should do it
lets look at one more thing
Chlorine generation
There may be night that you need to run it 12 hours for chlorine and other nights 5 or so
It all depends on many factors
sun,heat,number of swimmers, sun tan oil and so on
The biggest thing you can do wrong is to not use the pool If it is not being used every day you should brush sides and floor every 3 days or so. The pump is not strong enough to circulate the water properly
One more thing that I do and I have not changed my filters in this being my 3rd season
I have 2 one is always drying
Start with a dry filter and have the other clean and drying
Change them every couple of days.
Never try to use a wet filter it does not work like a dry one
Dont ask why it is just one of those mysteries
Also periodicaly take the hose off the front of the motor your inlet hose this can build up hair and debris that gets in from skimming
Good Luck
Don't forget to rate this
Posted on Jul 28, 2010
How do you clean plates on intex saltwater
Remove the salt cell housing and plug one end. Pour cell cleaning solution into the housing until the cell is covered. The cell is clean when no further bubbles are formed and you can see shiny metal cell plates.
Remove the cleaning solution flush the cell with clean water and install the salt cell housing back into the system.
Jul 24, 2012 | Intex Automatic Salt Water System for ...
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
Have an intex 16 x48" salt water pool generator
I checked the Intex web site and here is what they said:
There are several things you may need to check and do:
- Test the salt level first with Test Kit, and add salt as needed.
- Remove the electrolytic cell for inspection and clean it if necessary.
- If code 91 still appears despite the above steps, there might be a possible electrolytic cell
failure. Please contact Intex Service Center, and replace the cell if needed.
NOTE: Always turn the power off and disconnect power cord before cleaning and servicing.
I hope this helps.
Aug 24, 2011 | Intex Automatic Salt Water System for ...
Recently installed Intex saltwater system, all of a sudden, have green forming around walls of pool. All levels look okay; except chlorine is a little low and PH is very high...I ran the boost cycle last...
Once you get the "Green" stuff on the walls, you must brush it off.. and one boost cycle will not do.... Make sure you have the correct salt level!!! Keep in mind..big pools can take up to 350 lbs of salt... Now...set you pump at 12 hrs and you chlorinator at 10 hrs between those 12 hrs.. Run this cycle and you should see results within 2 to 3 days... Clean you filter and rinse your electrolytic cell after 3 days because you will have dead algae. After the water turns clear, you can then lower your cycle to 10 pump and 8 chlorinate.. Good luck! hope this helps!
Jul 19, 2011 | Intex Automatic Salt Water System for ...
Hello I have a 15x48 intex above ground Easy Set pool and saltwater system. All was working well for about a week and a half. I couldn't get my ph and TA levels right so I brought a sample to my...
I've been running mine for 2 years without checking anything other than the free chlorine level and it's always crystal clear without adding NO CHEMICALS. Make sure you have the correct salt level and start the unit. Take a water sample at the discharge after the chlorinating light comes on and check to see if it measures chlorine. Should be slightly yellow color. If so, your unit is producing free chlorine.
Jul 13, 2011 | Intex Automatic Salt Water System for ...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Code 91
If you have hard water in your location you may want to try cleaning the electrolytic plate. I had the same issue where no matter how much salt was added I had code 91. I shut the water down going through the filter / generator. Pulled the outlet hose off and put on a cap. Pulled copper cell out and filled chamber with vinegar. Put cell back in and let set for 1 hour. Fluhed it out and hooked everything back up. Nop more salt problems. The process is in the book.
Jun 07, 2010 | Intex Automatic Salt Water System for ...
I JUST SET UP MY INTEX SALT WATER SYSTEM AFTER DISOLVING 140 LBS OF SALT IN MY 18' X 48" EASY SET POOL. AFTER ONLY RUNNING FOR 2 HOURS, IT STARTED BEEPING LOW SALT. DOES THIS SOUND RIGHT AFTER JUST...
It is possible that you do not have enough
even after disolving the salt by siring it up you need to run the filter for at least 24 hours to really disolve and mix your salt
even though you cant see it it is still not equally distributed through the water
once you have run the system for 24 hours check your salt content
It should be as close to 3000ppm as possible
a test kit will cost about 11 dollars for ten tests
Jul 22, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
701 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
