Question about Uniden Atlantis 250g Handheld Vhf
How to change power on default channel to something other than channel 16
  • 560 Answers
Hi. Atlantis 250g is initially set for USA marine channel 16 but will keep the last channel that was selected when turned back On.
Posted on Jul 28, 2010
  • 1 more comment
  • ejd3rd Jul 29, 2010
    Sorry to say, that is not true. No matter what channel I have the radio
    on, if I turn it off and then back on it switches back to channel 16.
    I even tried to program channels in memory and select one of them before powering off and back on, same results, channel 16.
    Help me
    Ed
  • Liza Halbrook
    Liza Halbrook Jul 30, 2010
    I will do a research why its not keeping the last channel on memory. Mine always keep the last channel used.
  • ejd3rd Jul 30, 2010
    I have tried to find information and have come up empty. Even a request to Uniden tech support has gone unanswered so far.
    Ed
    President:
  • 2,185 Answers
The default channel is always 16. Do you mean programming other channel? Maybe the instruction below might help. Otherwise, please see this link for further instructions. http://www.uniden.com/pdf/ATLANTIS%20250-BKom.pdf
  • ejd3rd Jul 28, 2010
    You are correct. When you turn the radio on it always sets its self to
    channel 16, no matter what channel you were on when you turned it off.
    I want to set (program) the channel that comes on when you turn the
    radio on. Or at least have the radio come back on to the channel I had
    it tuned to when I turned it off.
    Sorry I forgot to add that I have read the manual front to back and
    back to front. There is no information in it reguarding the default
    setting or how to change them.
    Ed
I have optima hd71- ceiling mount hooked to hdmi sattelit tv-and samsung home theatre - hd channels give me full screen- normal channels with 16:9 does not - have 2 vertical grey bars -tried all adjus
You're projector is most likely fine. Check your satellite box. Go to the menu and see how its set to display video. It may be trying to up-convert TV signals. Try different adjustments from there to see if you see any change.
Oct 27, 2014 | Optoma HD71 DLP Projector
AV1 input question
The TV probably defaults to the RF channels. If it is an analogue only tuner model then it will go to the last used/programmed RF channel.
Sep 04, 2014 | Televison & Video
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Jun 07, 2014 | Night Owl Optics Night Owl Scorpion 168500...
Hxct16e
This is all I can find, might do the trick;
When changing the multiplexer to NTSC or PAL all other settings
are returned to the factory defaults.
The multiplexer can be used with either NTSC or PAL systems.
To set it up for NTSC operation:
1) Turn off the power
2) Press and hold the and {M} buttons.
3) Turn on the power
To set up the multiplexer for PAL operation:
2) Press and hold the and buttons.
Password Code User1 (1111)
User2 (2222)
User3 (3333)
User4 (4444)
Supervisor (5555)
Apr 03, 2014 | Honeywell Hxct16e 16 Channel Color...
Change default channel on cable box
Called the cable provider, Time Warner, and used the "settings" menu to navigate to power on channel, where I selected the default channel.
Nov 13, 2009 | Atlantic Scientific Network connector
I can't work out how to change the default input Sony KV-24WX1U
Don't think it can be done,you'll have to change it manually or it should go to AV1 when you turn on the cable decoder.
Jan 08, 2009 | Televison & Video
Help
Hi if you click on control panel, click on hardware+sound,then click on the recording tab find it will show up as microphone USB Codec click on it, click the properties button,click on advanced tab,
in the default format make sure that " 2 channel,16-bit,44100Hz (cd quality)" is selected, the incorrect default is for 1 channel.
Hope this is of some use to you.
Regards leo21682
Dec 29, 2008 | ION Audio TTUSB10 Turntable
Installer code
Hit menu button, top right of jog, installer code is 3477, then use jog and dial to change settings. These must be done locally!
May 21, 2008 | GE Security DVMRe-16CT-600 16-CHANNEL...
Intaller code
The factory default code to reset the system is 8111, however this will reset all program functions back to the factory settings, with the exception of the time and date. The default Operator code to use the system is enter, enter, enter, enter. This should allow you to operate the system.
Uniden Atlantis 250g Handheld Vhf Logo
41 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Greg Cann
Greg Cann
Mike Marcotte
Mike Marcotte
Are you an Uniden Boating Expert? Answer questions, earn points and help others
