Question about Antec SmartPower SP-500 (ASKU37152) 500-Watt Power Supply
The transistor 2SK2082 switcher always broken for device SP-500-48DI
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Always broken? How many times have you replaced it?
Posted on Dec 25, 2014
Have a JVC sub SP-PWM606 all speakers work except sub. found a blown cap on what I assume is the sub's amp replaced 2 caps- still no sub
Sub woofers are basically mono amps. It's likely that either a fuse has gone, on the sub, due to the blown caps. Or more likely the main power amp device of the device blew the caps. I suspect if you replace the IC or transistor(s) on the heatsink then the device will come back to life.
Feb 04, 2018 | JVC Audio Players & Recorders
I have a cheap Chinese power supply. My problem is it runs at full power all the time it always shows 18 volts no matter where I turn the knob.. Funny thing is sometimes it does work. Its a solong
It has a bad feedback connection in the regulator, or (if it's a linear power supply rather than a switcher) there's an intermittent short in the pass transistor. If you provide the make and model number, maybe I can give you more specific information.
Aug 05, 2017 | Power Computers & Internet
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
I have a Kramer VP729 video/audio switcher stop getting signal from hdmi 1 and 2 inputs. I have checked HDMI cables they are working. I have turned off receiver reset it to factory settings and reprogram...
The 729 is a pretty old box and only accepts HDMI @ 1080i 1080p. 720i 720p 480i and 480p
Because the 729 is HDMI compliant, and HDCP compliant, you cannot display an HDMI signal on a computer monitor which will not display a content protected source.
Connect your source directly to the display, if that’s ok then try through the switcher.
Check for the latest firmware from Kramer,
You can always call their tech support team.
Nov 24, 2017 | Kramer ProScale VP729 Videoaudio switch ...
Turn hdmi2 on
hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Sep 09, 2010 | Samsung LE32A457 32 in. LCD TV
Not getting fuel. told not to use the rear tank
I had an 86 F150 with dual tanks, it had a similar problem. The problem ended up being the switcher valve (switches from one fuel tank to the other). Mine was electrically controlled and would switch from rear tank to front tank, but (front tank also had a leak) would not switch back to rear tank. I found out that my switcher valve (after I tried rebuilding the switcher valve myself, and determined that it was not repairable and needed replacement) was defective. They are also not cheap-about 10 years ago it was about $150! Don't know if yours is the same model, but I found the easiest thing for me to do then was remove the front tank, since it leaked (metal mounting straps worn through in spot where insulation came out sideways), and remove the switcher valve. I always left my tank switch set to REAR (dont know if anything would have happened if I had moved it to FRONT anyway, with valve and tank gone) and it always worked fine from then on out.
What you need to do is probably a 2 man job: Have someone inside the cab have ignition on and work the switch from one tank to the other, while you are underneath the truck at the switcher valve. Your job would be to determine if the valve actually works both ways, or just one way, or not at all.
Also there are fuel filters in several places: there is one in the switcher valve, further up along the frame toward the engine, and should be one somewhere on the engine, too. Also each tank should have an in tank pump. Several places to check, it's a big job, its messy, gasoline is toxic, not to mention explosive. Wish I had better news for you.
Hope I've been helpful.
Mar 13, 2010 | 1987 Ford F 250
Switches on then goes back to standby mode.initially it would show a the picture pressed vertically
problem on three things.
1.power supply: some of components may be damage,such as,EHT transformer ,Capacitor,diode Mos fat ,
2. Video card
3. If it self check thoroughly or not go to work shop.
Feb 12, 2010 | LG RU-27FB30C TV
NO POWER EVERY THING CHECKS OKEY The switcher transistor was shorted also the bridge rect. A small resistor was open next to the switcher. H.O.T. okey .I replaced all of these and the tv is still dead....
switch mode power supply are very finicky check the opto coupler isolator of proper operation, also is there a non polarized capacitor at the high or hot side of the power supply, if so replace it, this can be the cause of the fault to begin with, usually around .47 mfd to 4.7, non polarized.
Good luck
Jan 28, 2010 | Sanyo DS24205 24" TV
Dfx9000
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Jul 08, 2008 | Epson DFX-9000 Matrix Printer
Antec SmartPower SP-500 (ASKU37152) 500-Watt Power Supply Logo
288 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
