Question about Dehumidifiers
When the bucket is full it is not turning off and overflows.
What you should do is remove the bucket and look for a pressure switch which is most of the time under the bucket and test it by pushing down on it's plunger, if the unit turns off either the switch needs adjusting or is there is a plate above it needs the be bent .
Posted on Jul 28, 2010
Have model 043-6121-4 connected with a garden hose yet the bucket continues to fill.
Where are you running the hose to drain it? If the end of the hose is higher than the top of the bucket, then the bucket will fill and overflow. The drain hose must drain out into some place that is at least lower than the top of the bucket. That way the bucket won't overflow. Basic physics.
Mar 15, 2015 | Dehumidifiers
The bucket fills up but we have to put a towel down because it leaks all over the floor. What could be wrong ?
Good Afternoon Friend,
I understand that the bucket fills with water and overflows on your Frigidaire dehumidifier, model# FAD704DUD. Please make sure your dehumidifier is installed on a level that will support it with a full bucket of water. If the dehumidifier is moving when it fills with water then this could possibly be the cause of the bucket overflowing. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
Does not shut off and overflows
In most cases this problem is caused by the water collection bucket not being installed properly. It may not have been pushed in far enough to allow the full switch to activate when needed. Be sure that each time you remove the bucket to empty it and then reinstall it, that the lift handle of the bucket is all the way in down position and that the bucket is fitting squarely into the holder from top to bottom.
Note: Your specific model has been discontinued by LG. However, some parts are still available if needed.
If you run your dehumidifier constantly and don't want to make a repair to it. You may want to consider using a drain hose, rather than the water collection bucket. This would require a floor drain close to the unit, though.
Hope this helped you to troubleshoot and solve the problem.
Jun 16, 2011 | LG LHD45EL Dehumidifier
AFTER A YEAR MY DEHUMIDIFIER WONT TURN ON, IS THERE A FUSE HIDDEN SOMEWHERE IN THE UNIT THAT COULD POSSIBLY BE BLOWN? IF SO MNCOULD YOU POINT ME IN THER DIECTION TO REPLACE IT. THANK YOU
its the bucket switch on the unit thats bad,it controls the water level overflow so unit shuts off when bucket is full,its at the top rigt side of the bucket mounted to the float in the bucket and there is a replacement available part # AP3136674,on some units depending on the mounting hole size,you may need to use some old switch mounting parts on the new switch so it fits
Apr 10, 2011 | Goldstar DH504EL Dehumidifier
Even though I have emptied the bucket the bucket full light will not turn off and the dehumidifier will not reset. I tried unplugging the unit but when I plug it back in it still says bucket full
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 29, 2010 | Haier 45-Pint Dehumidifier
Why would my dehumidifer overflow
the sensor for the full bucket light is either bad or stuck open, either way it is not sensing the water and turn off the unit. Hope this helps tim
Aug 26, 2010 | Whirlpool Dehumidifiers
Do i need to disable the collection bucket to attach a drain line to my Matag dehumidifer M7DH45B2a? Or does it keep a full bucket and drain the overflow to the tubing drain?
No just connect the hose and open the hole to the unit to drain and return to usauge. it will fill to the drain opening and drain.
Aug 23, 2009 | Maytag M7DH45B2A Dehumidifier
My LG dehumidifier does not turnoff when full and overflows
make sure the float in the bucket isn't binding on something. The float actually activates a button that you can see when you remove the bucket. pull the bucket out and see if the unit cuts off. Maybe the button is stuck.
Aug 11, 2009 | LG LHD45EL Dehumidifier
Bucket overfills to the point of spillage
The float is the main feature that keeps it from overflowing. I have no idea why there would even have to be an adjustable component in the circuit. The float is connected to an On-OFF microswitch and may be tested with the unit set to run.
Remove the bucket and manually push upward on the float. If the unit stops running then the bucket may be misalgned,(Make sure float is on the inside of the bucket and not lodged behind the bucket).
May 26, 2008 | Dehumidifiers
Dehumidifiers Logo
93 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
