When my computer is turned on my monitor doesn't turn on until I hit the power button then when I do it says analog power saving mode for about 3 seconds then turns off again. I tried using a different monitor but still didn't work.
  • 6,826 Answers
Seems like your computer is asleep or something,
Posted on Jul 28, 2010
My HP A735W is turning on but stays in power save mode and no key board or mouse function
I think the issue is your monitor. If the monitor constantly says Power Save Mode and not let anything else display then the monitor might be bad. See if we can isolate the problem by the steps below.
Try booting up in Safe Mode and see if the monitor works ok.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it works ok in safe mode then the monitor is ok and we might have an issue with a setting.
Try connecting another monitor to your computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor then the issue is with the computer (possibly the video card).
May 20, 2012 | HP Pavilion a735w (PL308AAR) PC Desktop
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
My main home computer whener turned on goes to analog powersaving
LG does not show the 1750 monitor on their web site. It did show some discontinued monitors including a 1752, but there was no information available about them.
Another LG site said to use the far right bottom to auto adjust....for another monitor.
My HP has four buttons, MENU, <, >, and Return (also AUTO). Menu opens the monitor dialog box, with the arrow bottoms shifting through the menu. Select an item with return, then arrow to your selection, menu is also your exit button.
You may have a power saving selection here.
Also check the control panel for the POWER OPTIONS properties. A power scheme selection here will also change the mode of your monitor.
good luck
Feb 18, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
How do i getr the creen out of analog power save
Usually hitting a button on the keyboard or moving the mouse works.
If it is really a problem go into your display settings through the control panel, access the power options and stop your monitor from going into powersave mode.
Sep 27, 2009 | LG 19" Widescreen Flat Panel LCD Monitor
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Oct 13, 2007 | Dell E173FP 17" LCD Monitor
"analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Sep 09, 2007 | LG Flatron L1750S 17" LCD Monitor
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Computers & Internet Logo
141 people viewed this question
Alun Cox
David Payne
David Payne
