Phaser 7300DT, all of a sudden my yellow only prints at the very bottom solid and then really faded throughout the rest of the sheet. The imaging unit is at 54% life remaining and toner is says more than 1600 pages remaining and is OK. Fuser is brand new and transfer unit is 76% life remaining. What should I do, the parts to this printer are so expensive, I hate to buy one part and it be another.
  • 1,110 Answers
Remove the yellow toner cartridge and shake from side to side while keeping the cartridge level. Sounds like the remianing toner in your yellow toner cartridge is not evenly distributed.
Posted on Jul 28, 2010
Why is my printer printing faded colours
Hi Kath,
I expect you have it sorted by now.
I think you might have had one off the developer tanks stuck or broken. If the developer roller does not turn then the colour quickly fades along the page. If you tried to do a test page and that was good then there was nothing wrong with that side of things.
Good luck.
Jul 16, 2014 | Xerox Phaser 7400DN Laser Printer
Yellow streaks on phaser 7700 prints
You have a bad yellow developer housing and it will need to be replaced. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered here: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
Jul 05, 2009 | Xerox Phaser 7300DT Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 7400 Print Quality (Solid Fills)
i cant remember if the led's are interchangeable or not.. if they are, mark up one of them and swap positions, noting any change of appearence, you should be able to use this method to see if one is faulty, its doubtful all 4 are gone, but think u are barking up the right tree! other possibility is that there is a charging issue with the drums...could be a psu issue, hope this is of help to you, Markus.
Jul 28, 2008 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 6250 started printing bad
That really sounds like the imaging unit cleaner has an issue.
If you have one try the imaging unit, I really suspect that is your problem.
Black is Faded or Missing Step 1 Clean the Laser Windows and Remove Excess Toner From the Imaging Unit Step 2 Check or Replace the Imaging Unit Gear Retaining Pin Step 3 Replace the Imaging Unit (installation instructions) ic-film.gif
See if this link works. Xerox is infameous for these not working.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=842,E=0000000000019251353,K=6024,Sxi=13,Case=obj(19377)
Apr 08, 2008 | Xerox Phaser 6250DP Laser Printer
Tektronix phaser 7300 uneven inking
sounds like a bad cyan developer housing. Or that somehow the housing has come out of its mounting, but I cant think how that would happen. There are some rails in the machine that may have also come loose.
You have to remove the IBT ( transfer) assembly to look into that.
Apr 07, 2008 | Xerox Phaser 7300DN Laser Printer
56 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
