Question about Whirlpool GEW9250 Electric Dryer
Wrinkle light shield flashing when turn dryer on but dryer wont s
On my dryer, it will power on but thereis the wrinkle shield light flashing nd it will not start, can you tell me whats wrong, its front loader only 5 years old!!
huuum
  • 750 Answers
SOURCE: Sport Duet dryer will not start, even though power light is on
If the unpluging for the night helped reset the system and then worked?
Then there is an electronic problem that needs to be addressed and diagnosed.
You have 3 mor months warranty so I suggest you start using it now .
Therefore you have a record of this problem before it ends and if anything happens after the end of your warranty they will help you anyway or replace the dryer for you ,ANYWAY! Yes they do that if they see there were defects prior to the end!!
If you ever have a problem after the warranty is up call, " Whirlpool Consumer Affairs"
They have the power!
Make an appointment with Whirlpool now and it will cost you nothing.
Let me know what they find.
Huuum
Please remember to leave me a rating!
Posted on Oct 10, 2008
  • 19 Answers
SOURCE: Whirlpool Combo Washer Dryer LTG6234AW2 - Dryer wont heat
Go to: RepairClinic.com
There you can troubleshoot
you appliance.
You'll need make & model #.
Posted on Nov 16, 2008
  • 208 Answers
SOURCE: my front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Posted on Jun 22, 2009
thutch6911
  • 15 Answers
SOURCE: my duet front loader dryer has no power
If you have 220v going to the unit you want to take the bottom pannel off. It should be three tork screwws. Then there is a little white fuse mounted on the blower houseing. This is the most common problem especally if your vent has not been cleaned in a while. (over 3-4 years.)
Posted on Jul 30, 2009
  • 91 Answers
SOURCE: Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Posted on Jan 02, 2010
My duet dryer model GGW9250PW3. front loading,won't start.
It is probably the thermal fuse (start fuse) located on the blower wheel it's white about 2" long with two blue wires going to it. Try that first.
Aug 02, 2015 | Whirlpool Dryers
Lights come on, press start and nothing ..
Start Switch is bad, When they go out it leave's a open circuit and all light will come on but no action.
After the circuit is closed then it tells the dryer to start cause the circuit activates both the timer and the motor.
Good Luck
Mike Z
Dec 01, 2013 | Whirlpool Cabrio WED5500X 27" Front-Load...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
I have a whirlpool duet front load dryer. The control panel lights up but, the start button will not work. Also, when I turn the knob the lights will not follow my new selection. It is not locked and the...
As for the knob not alligned with selection, pull the know out and put it back. Remember where it was when you pulled. Now power start. Are you pressing the button start a bit with force to see if it engages. Looks like you may have don but just in case. Then it could be your start switch button that need attention.
Aug 06, 2013 | Washing Machines
I have a whirpool duet electric dryer model WED8300SW0 and the wrinkle shield light flashes, the cyle knob is on one cycle and the light indicates a differant cycle everytime it is changed. the start...
the first thing to check is the ribbon connectors from the front board to every other board.gently unplug them and clean with alcohol and plug them back in.hope this helps.
Feb 01, 2018 | Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
The washing detergent doesn't wash out of the clothes it leaves marks on the fabric. what is wrong?
Too many clothes in the load , reduce by 25%
Switch to an old fashioned soap powder that has more agents in it to help it dissolve
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
331 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
