Question about MSI 845GLMS-L (MS-6754G-020) Motherboard
I can't load my boot menu .. What should i do? i need to boot from flash device but i ca't
    President:
  • 1,851 Answers
What kind of keyboard do you use, wireless or PS2? Do you get any message? Does the del key works?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jul 28, 2010
Wen I turn on PC using Windows Vista I get the warning no boot device available. What does this mean?
Hi britchel07,
I see that you are having issue booting into windows on your system.
I can help you with your concern, we can first try to boot into the Hard drive manually, follow the steps below,
1. Power your computer ON then keep on tapping the F12 key on top the keyboard until you get the Boot Menu screen,
2. On the Boot Menu screen select the Hard drive it maybe listed as SATA or HDD, but if it is not listed then we may need to try a different option, on the Boot Menu the Hard Drive should be the first one on the list.
3. Highlight the Hard Drive on the list then press Enter to make your computer boot into the Hard Drive.
if this does not work then your Hard Drive may not be detected by the machine, why I really can't tell there are many possible causes, but we can try other options to see if this can be rectified.
I believe that you have a Desktop machine, we will need to open up the tower to check if there are lose cables inside from the Hard Drive to your systems Motherboard, inside you should see a Flat Orange like red colored cable sometimes Blue that should be your SATA cable going to your Hard Drive from the Motherboard, try reseating the SATA cable to make sure it is properly connected and also check the SATA power cable just to be surem it should also be a black flat cable connected to the Hard drive just right nest to the SATA cable, after reseating the two cables try turning the computer ON again and see if the system will boot into Windows.
If still you get the Error no boot device found then you may need to get a new Hard Drive for your system.
I hope that this will be helpful with your concern, Have a nice day.
Apr 06, 2011 | Dell (Inspiron 531) PC Desktop
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
Mar 09, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
How to enter to boot menu
Try to press F12 during startup. You need to press F12 before windows starts to load.
Another option is press F2 during startup and change the boot device in the boot device priority section.
Done that Save and Exit setup
Mar 13, 2010 | ASUS F3Jm Notebook
Just got the iPod Touch 3rd gen 8GB model - trying to surf the net - why does it take so long to load a site? eg. tried BNN.ca and shaw.ca - takes forever
you must remember that is a portable device and will not load fast like a computer, and the sites you are trying to visit may not have a mobile version and iphone and ipod touch does not support flash.
Dec 08, 2009 | Apple iPod touch
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
PC will not boot.
go to windows start menu and click on RUN. type in "msconfig'' without quotation marks and click enter. the computer will load the system configuration utility, on the general tab, select normal startup option, then click on the BOOT.INI tab the click on CHECK ALL BOOT PATHS,a dialog box will appear to tell you whether the windows boot directory is OK or not. if it displays that they are Okay, then there may be that a virus has affected those files. you ca also type in "sigverif" without quotation marks, on RUN to launch the windows file verification, click on start to check important windows files for their correct version. try restarting the computer. if your system still can boot, open the computer case to make sure that the hard drive, and RAM are connected correctly. if you still having problems, notify me.
Dec 03, 2008 | Northgate Athlon XP 400FSB Barebones...
Reboot
Hi satiewe, no not you're CD. You'll need to enter the notebook's bios. How to get into the bios? Right after you press the power on button, start pressing the delete key every two seconds. The bios main menu should load. If pressing the delete key fail to load the bios menu, try again & press the F2 key every two seconds. The main menu will look like this:
1583ec1.jpg Look at the bottom of the menu & there are instructions on how to move about while in the bios. Go to the title, Advanced.
Listed to the right of; [PATA Primary Master : xxxxx] Where xxxxx is the model number of the hard drive, (Ex: ST80325B). Write this number/letter down. Than go to Boot .
Under boot is, Boot Device Priority. The normal order should be;
1st boot device, [floppy]
2nd boot device, [CD-ROM] - model name.
3rd boot device, [Hard disk drive]? The name of the drive was listed at the main menu as, Pata Primary Master (What you wrote down is what must show here). Than save the bios change & exit. The system will restart. If you placed the correct drive in the correct order you're system will start up.
Good Luck!
Mike
Jun 26, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
MSI 845GLMS-L (MS-6754G-020) Motherboard Logo
73 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
