Question about Raymarine C120 GPS Receiver
My Raymarine C 120 GPS intermittently stops working.
MyRaymarine C 120 gps intermittently stops working. I lose the ship icon on the screen. Sometimes it works and sometimes it does not. Sometime it comes back on its own on the same boat trip and sometimes it stays off the entire boat trip. I have checked the wire and cable connections and have found no issues. I have checked the sensor for moistue/corrosion and found no issues. Any ideas?
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Posted on Sep 02, 2010
Manual for e 120 raymarine
You can download manuals for Raymarine E120 GPS free of charge here (click on 'Manuals & Docs' tab at that page).
Jun 24, 2010 | Raymarine E120 GPS Receiver
We lose fix info. on the c120and the Auto pilot has no display. The problem is intermittent
This sounds like a problem with the receiver. If you can not get GPS fix (sometimes) you will have to start looking at the GPS antenna and cable. If the unit is new check out the location of the antenna. As with anything that works with satellites it need a clear view of the sky to fix onto the "birds". A GPS connects to numerous "birds" at a time, so ensure that the antenna has a wide angle view of the sky. If it is old you will have to start looking for connection problems. This is usually the case when the fault is intermittent. Check for possible water damage and loose or less than adequate connections. Also ensure the cable is in a good condition.
Apr 03, 2010 | Raymarine C120 System Pack C120 Raystar...
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
C120 powers on but screen rolls
press and hold fist softkey during power on to reset, reinstall software, otherwise, ship to raymarine
Jul 12, 2009 | Raymarine E120 GPS Receiver
No fixed postion has ? over gps icon in upper right corner of unit
touch lower right hand corner and see if it reboots software. will probably lose all info saved
May 30, 2009 | Raymarine C80 GPS Receiver
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Ray Marine c120
Send unit back to Raymarine. Two year warranty. I just talked to the factory about a communication error between the E series and the radar. Radar just stopped communication between radome and E unit.
Jan 31, 2008 | Raymarine E120 GPS Receiver
Raymarine C120 GPS Receiver Logo
339 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
