Question about Dell (E210882) Motherboard
I messed the bios up on a Dell Dimension 8400 pc. The HD completely died, so I have no OS on the pc, so I can't just simply run the exe bios update from dell. Is there some USB utility that I can use to fix this issue?
    Problem Solver:
  • 9 Answers
Go here if you can unmount the bios eeprom they will reprogram it for you or send you another of its type with your bios on. I have used this service a few times. Never failed me. GL
http://bios-repair.co.uk/
Posted on Jul 28, 2010
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
When trying to boot PC all i get is black screen and message:- X300 SE 128MB BIOS P/N 113-A33406-100. Have replaced bios battery on motherboard an checked connections etc but still displays same message....
no problem friend please open your cpu shutter and you can see here a cell like watch's cell plug it out and replace it with the new one and start your computer now your this problem is 100% solve. thanks
Jul 14, 2011 | Dell Dimension 8400 PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Dimension 8400 locks up. Keyboard won't respond.
Generally and indication of a software issue that is locking the system. There can be hardware causes too.
  1. Run diags on the system (From Resource CD or F12 menu) see if any failure. If you have a hardware failure then address it and see if the problem is solved.
  2. Update bios and drivers from support.dell.com
  3. Edit MSCONFIG, startup group, remove entries that are not required (Generally only AV and printer scanner items are needed here, most other items will function without and item here)
  4. Edit the Virtual Memory settings, and set it to Custom and an amount double the RAM (EG: 4 GB RAM set initial and Mas to 8200 MB VRAM)
Apr 04, 2010 | Dell Dimension 8400 PC Desktop
I want to backup my BIOS to a disk for emergency use.
I've done over 100 bios upgrades / flashes / etc and not once have I ever had any need to restore a backed up bios.
Here's what I found on the net
Hope this helps, it's not a solution per say but honestly it's probably overkill backing up that bios file FYI.
Best of luck!
Feb 27, 2009 | Dell Dimension 8400 PC Desktop
My Dell Dimension audio no longer works
for update your drivers use this link - http://support.euro.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=3&impid=-1&servicetag=&SystemID=DIM_PNT_P4_8400&hidos=WW1&hidlang=en&TabIndex=
Dec 25, 2008 | Dell Dimension 8400 PC Desktop
Dell (E210882) Motherboard Logo
117 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
