Question about Texas Instruments TI-84 Plus Calculator
Locate % button
Sir, cannot locate the button or way to find % button on TI-84 Texas instruments Calculator, am only a novice Barry
  • Barry Norton Apr 30, 2008
    Thanks for the come back on how to resolve my problem,am waiting on my friend to come to my house, I don`t feel comfortable to have a crack at doing this as yet, as I said i am a novice to this sort of thing, I will advise and let you know how we went.
    Best Regards Barry
    Problem Solver:
  • 8 Answers
There is no % button on the calculator, but depending on what you need it for, there are some simple basic programs that could work for this. If you just want to find percent from a fraction or decimal, use this one.
Hit the program button and press right two times the enter to get a new program.
Name your program "PERCENT"
hit enter
hit program, right, enter, to paste "Input" onto your screen
In quotes, put "Number?", then a comma, then N (not in quotes)
Press enter to get to a new line.
Enter "100N-->N" (once again, not in quotes)
The arrow is found directly above the on button
Press ENter again, putting you on the third line.
Hit program, right, 3 to paste Disp on your screen.
Put N after, not in quotes
Your screen should look like this:
PROGRAM:PERCENT
:Input "NUMBER",N
:100N-->N
:Disp N
Press 2nd Mode to quit, then hit the program key and select program Percent to run (making sure you are in the "Exec" menu)
Hit enter to run your program: it should turn decimals or fractions to percents.
Don't feel that your intelligence is being insulted by me giving explicit instructions that may be below your level in programming: I did not know whether or not you were proficient.
Posted on Apr 30, 2008
Where is the '!' button on the TI 84 plus calculator?
There is no such button. The factorial function is in the probability submenu of the math menu. Press MATH left-arrow 4 to access the factorial.
Jul 23, 2014 | Texas Instruments TI-84 Plus Calculator
The system cannot find the file specified
Connect the calculator to the computer and turn it ON. Open the TI connect software. Locate your file on your computer, do a CTRL C to copy. Drag and drop the file on the Main window of TI connect. If file is compatible with TI 84 Plus, it will be transferred to your calculator. Use the Memory management of the calculator to locate the transferred file in calculator.
Dec 17, 2013 | Texas Instruments TI-84 Plus Silver...
Who invented this calculator and where it came from?
The first graphing calculator was invented by Casio Computers. of Japan in 1985 It was the Casio FX-7000.The lead engineer on the Casio 7000 development team was Hideshi Fukaya. About 5 years later, Texas Instruments introduced its first .
The Ti 84 Plus was introduced in 2004. Before the TI 84 plus there werer other graphing calculators by TI: 80/81/82/83/85/86/92/73
Aug 28, 2011 | Texas Instruments TI-84 Plus Calculator
If Texas Instruments TI-84 Plus Calculator hangs on screen "RAM CLEARED" , what should I do?
You should try a few different things:
1) Press the Clear button
2) Press the On Button
3) Remove and replace the batteries
If the final step does not work, you should also remove the backup battery. This is located UNDER the AA batteries. You will need a small screwdriver to remove the cover. Replace everything and turn the calculator back on.
Feb 12, 2011 | Texas Instruments TI-84 Plus Calculator
How do i type a fraction in my Texas Instruments TI-84 Plus Graphing Calculator
The TI-84 doesn't really work with fractions. Type in a fraction as a quotient. For example, to type in one-half, type ( 1 / 2 ).
Oct 21, 2010 | Texas Instruments TI-84 Plus Calculator
Where is the equal sign on the ti 84 plus
hello sir, Press "second" "math", and it should be the first thing listed. If you need other commands hit "second" "0" that will enter the catalog and you can press any letter (without hitting alpha) to jump to that letter in the list. Please click on the following link to see the manual of the TI-84 Plus Calculator: http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
kindly rate me.. thanks for using fixya..
Mar 03, 2010 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes and seconds button
Press the blue "2ND" button in the top left hand corner, then locate the "ANGLE" button, or "APPS" button and press.
It should give you a list of symbols.
The first two are: Degrees and Minutes.
As for seconds, press the green "ALPHA" button, then locate the "+" and press.
May 19, 2009 | Texas Instruments TI-84 Plus Calculator
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
TI 84 moving slow-have to hold buttons downv
If a piece foreign material such as a pencil lead is lodged in the I/O port of the calculator, it may create a short causing the calculator to respond slowly to key press entries.
If the piece of conductive material can be removed, it may restore the calculator to normal operating condition.
Jan 16, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
1,764 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
