Question about Bosch SHU9915UC Dishwasher
Our Bosch dlx series dishwasher slowly fills up when it isn't running. If we don't use it for a day or two the water will flow out the bottom. When it runs it runs normally.
  • Bosch Master
  • 2,605 Answers
Welcome to Fixya ! You've come to the right place. The problem you're experiencing sounds like (unfortunately) a common one.
The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's.
The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic.com, apwagner.com etc.
Do a search for part # 1105846 at repairclinic ( that is their part # not B/SH/ ) you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward.
Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness.
Good luck.
macmarkus :)
Posted on Jul 28, 2010
  • mcinnis870 Dec 03, 2010
    where is the water inlet valve located in the dishwasher ?
    Tx Ron
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Our Bosch DLX series dishwasher slowly fills up when it isn't
Hi, the problem is the water valve itself. Based on your description and the fact that this is a common issue with Bosch dishwasher's a new valve will resolve the problem. You'll need a new valve assembly part # 425458 and it's available at most part's places or online. It is about $25 - $30. Let me know if I can assist you further. Thanks for using "fixya" for your inquiry. Please take a second and rate the info provided for you here. Good luck. Macmarkus :)
Posted on Mar 22, 2010
Testimonial: "thanks for the quick reply"
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 23, 2011 | Bosch Dishwashers
Our Bosch DLX series dishwasher slowly fills up when it isn't running. If we don't use it for a day or two the water will flow out the bottom. When it runs, it runs normally.
Mar 21, 2010 | Bosch SHU9915UC Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Sep 01, 2008 | Dishwashers
Bosch wont
Faulty inlet valve or water in the bottom tray which will activate the float swich and pump out any water. See that this moves up and down freely. Turn electrics off first.
Jun 18, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
Bosch SHU9915UC Dishwasher Logo
327 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
