On Monday Carlos drove to work in 35 minutes. On Tuesday he averaged 9 miles per hour more and arrived 7 minutes faster. How far (in miles) does Carlos travel from home to work?
  • 91 Answers
SOURCE: Dodge 318 overheating.
HI. It could possibly be the the thermostat is stuck shut. If thats the case when the vehicle warms up it will probably overheat all the time. The best way to tell is buy a new one and change it. They are usualy around $10.00 at any autoparts store. If you change it and it still overheats, it could be the waterpump.
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: Car Runs and Loses Power and Quits Running
Try cleaning the fuel pump filter. Under the seat behind the driver lift the carpet and you will find a round cover with six screws remove the cover. The fuel pump is directly below unscrew the retaining round plate and remove the pump. At the base of the pump is a small filter if it is covered in black muck that's your problem. clean and replace. job takes about 10 mins good luck. please let me know how you got on!
shauunswbc@aol.com
Posted on May 08, 2009
Molson02536
  • 3854 Answers
SOURCE: 1997 s-10 sames to get vapor lock
Change your fuel filter, it may have gone it's life time and is getting to dirty to let fuel flow properly. Your fuel pump to may be getting weak, if the fuel filter is dirty the pump works harder and heats up and could be over heating the fuel pump relay too. The fuel pump relay i believe is in the glove box behind a panel that say relay, there should be (3) in there and the middle one is the fuel pump's. switch then around after you change the fuel filter and if you get a chance, check your fuel pressure at the shredder valve. Good luck and hope this help's if there is a Auto Zone around you, you can ask to use the fuel pressure gauge to see what fuel pressure you have and they'll have the step by step instructions on how to do it and takes about 5 min to do and will have the fuel filter and step by step to replace that too. Keep me posted, be glad to help.
Posted on Jun 08, 2009
SOURCE: 92 cadi coupe deville won't start sometimes
the first one is your security light on?
Posted on Nov 04, 2009
  • 11800 Answers
SOURCE: Average kilowat consumption of a Toshiba Qosmio
Minimum (everything off and/or on minimum): 31.8 Watts
Idle (max. brightness): 42.1 Watts
Maximally (full load inclusive. WLAN): 64,8 Watts
Posted on May 25, 2010
How to fix on a 2005 dodge neon went driving the car till I get to a speed of 35 mile per hours it try to shut down and I release the accelerator and it goes back to normal
releasing the gas pedal and it gets going again
not very safe
is the engine light on
could be any faulty sensor in this engine diagram
maf clean might help
if a spark issue needs chasing
it could be a fuel problem
maybe bad fuel or blocked fuel filter
Oct 15, 2016 | 2005 Dodge Neon
1999 Monterey sport. What's wrong with the transmission?
WHY ON EARTH WOULD YOU WANT TO GO FASTER THAN 7 MILES PER HOUR IN REVERSE?? Automobiles are not designed to go that fast in reverse!
May 20, 2015 | Mercury Monterey Cars & Trucks
What are warrnambool westpac bank hours
Please be so kind as to tick the helpful box for me?
Trading Hours
Monday 9:30am - 4:30pm Tuesday 9:30am - 4:30pm Wednesday 9:30am - 4:30pm Thursday 9:30am - 4:30pm Friday 9:30am - 5:00pm
Feb 23, 2015 | Commonwealth Bank of Australia NetBank
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
What's the average ball speed?
The average ball speed for a bowling is about 10 miles per hour to15 miles per hour with professional bowlers averaging about 20 to 25 miles perhour, the power of the throw depends on the bowling game type you're playingand your physical strength. You can improve your throwing speed by practicingyour throws and strengthening you forearm.
Jul 23, 2012 | Sport & Outdoor - Others
Kwai Fang had some boxes of fruits for sale. She sold 35 boxes on Monday. She sold 1/5 of the remaining boxes of fruits on Tuesday. Then she had 1/3 of the total number of boxes of fruits left. How many...
  1. Number of boxes that she had first is X.
  2. After she sells 35 boxes she has X-35 boxes.
  3. On the tuesday she sells 1/5 of remaining boxes which is 1/5 of X-35 (you write that as 1/5*(X-35)).
  4. Now she has X-35-1/5*(X-35) which is equal to 1/3 of total number of boxes (1/3X).
  5. Now you can write an equation X-35-1/5*(X-35)=1/3X
  6. You put all Xs on one side and all numbers on the other.
  7. You should get this equation X-1/5X-1/3X=35-1/5*35 and then when you add and subtract everything 7/15X=28.
  8. From last equation you see that X is 28*15/7 which is equal to 60.
Aug 30, 2011 | Office Equipment & Supplies
Train A and B are traveling in the same direction on parallel tracks. Train A is traveling at 100 miles per hour and Train B is traveling at 110 miles per hour. Train A passes a station at 9:25am If train...
The first thing to figure out is the amount of time between the trains is 12 minutes. That would mean for train B to pass the station at 9:37 it would have to travel 22 miles in 12 minutes. Because, traveling at 110 miles/hour in 12 minutes the train would have travel 22 miles. Shown below shows the interpolation to come up with 22 miles.
Train A had to traveled 12 minutes so, it would have been 20 miles ahead of the station. Screened below shows the interpolation to equal 20 miles.
Though this calculation of 20 miles isn't necessary for the parametric solution that is being shown. It was very helpful in my solution in successive approximation. This parametric solution's starting point is at 9:37, not 20 miles ahead.
Using successive approximation, when train A traveled 200 miles in 2 hours, and train B was only 2 miles behind train A. At that point the time varibles needed to be broke down to minutes and seconds which gave me a real accurrate answer. Both trains were side by side in 2 hours and 12 minutes, and had traveled 220 miles from the station. You wouldn't believe how far the significant bits needed to be carried out to get such an accurate number. That's what gave me the idea to substitute, and use a parametric solution. In this solution the t (aka. time) is going to be substituted for the y axis. Next, I broke miles/hour down to mile/minute because, I knew the answer was in minutes: 2 hours and 12 minutes.
110/60=1.833333 so, -20+1.833333 t and 100/60=1.6666667 so, 1.6666667 t
Now load the equation:
Now let's look at the solution from the graph. Each line represents a train.
Notice how the two lines are converging. Where the two lines meet is the exact point when the two trains are side by side.
Substituting t (aka. time) for the y axis show that at the point when the trains were side by side equals 132 minutes. Or 2 hours and 12 minutes. The distance traveled x axis=220 mile from the station.
To a point successive approximation would have been messy, and hard to follow. Somethings can only be solved by using graphs, or better solved by using graphs.
Dec 20, 2010 | Office Equipment & Supplies
When turn on always says poor satellite reception,
Hi Carlos,
You are receiving that message because the GPS is unable to acquire satellites. Satellite reception can be limited due to one or more of the follow reasons: Poor view of the sky, GPS antenna not deployed, used indoors or other internal problems.
Try taking the device outside in full view of the sky - preferably with little or no tree cover, tall buildings, etc. and allow up to 2 minutes to acquire satellites.
If unable to acquire, it may require return to Garmin for repair. Contact Garmin based on your location and product below:
North America - Consumer Products (for all Garmin products except Apollo aircraft)
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
E-mail Product Support
Europe - Consumer Products (for all Garmin products except Apollo Databases)
Austria For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 43 (0) 3133 3181 0
Website
Belgium For all Garmin products except Aviation.
Friday: 9:00 AM – 15:00 PM (GMT/UTC +2)
Phone: 00 32 2672 5254
Website
Denmark For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM Central European Time (GMT/UTC +1)
Phone: 00 45 4810 5050
Website
Finland For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 16:00 PM (GMT/UTC +3)
Phone: 00 358 19 311 001
Website
France For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 33 1 5517 81 89
Website
Germany For all Garmin products except Aviation.
Monday – Friday: 8:30 AM – 17:00 PM Central European Time (UTC/GMT +1)
Phone: 00 49 898 58364 880
Website
Italy For all Garmin products except Aviation.
Monday – Thursday: 9:00 AM – 13:00 PM / 14:00 PM – 17:30 PM (GMT/UTC +2)
Friday: 9:00 AM – 13:00 PM / 14:00 PM – 16:30 PM (GMT/UTC +2)
Phone: 00 39 02 3669 9699
Website
Portugal For all Garmin products except Aviation.
Monday – Friday: 09:00 AM – 12:30 PM / 14:00 PM – 18:00 PM (GMT/UTC or GMT/UTC +1 depending on city)
Phone: 00 35 1214 447 460
Website
Spain For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 13:30 p.m / 14:30 PM - 18:00 PM Central European Time (GMT/UTC +1)
Phone: 00 34 934 972 373
Website
Sweden For all Garmin products except Aviation.
Monday – Friday: 9:00 AM – 17:00 PM (GMT/UTC +2)
Phone: 00 46 7744 52020
Website
United Kingdom For all of United Kingdom users and customers in unlisted countries in Europe, Africa and Middle East
Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
Phone: 00 44 808 238 0000
Website
Aviation Products Monday – Friday: 7 AM – 7 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-866-739-5687
E-mail Aviation Support
Apollo Aviation Monday – Friday: 8 AM – 4:30 PM Pacific Time (closed holidays)
US: 503-391-3411
US Toll Free: 1-800-525-6726
Canada: 1-800-654-3415
Garmin Europe Monday – Friday: 8:30 AM – 17:30 PM Western European Time (GMT/UTC)
+44 (0) 87 0850 1243
Fax: +44 (0) 23 8052 4004
Sep 18, 2009 | Garmin GPS
Computers & Internet Logo
Alun Cox
David Payne
David Payne
