Question about Ford Tractor Grill 2600 3600 4600 5600 6600 7600
My ford 7600 tractor pto not turning. the lift hyd
My ford 7600 tractor pto not turning. the hydraulic lift is working. i have changed the oil filter , i have changed the oil- was contaminated. i suspect the pto clutc has failed. where is it situated? how do you disassemble/assemble the clutch
tommyboinow
  • 324 Answers
SOURCE: ford fiesta hydraulic clutch not working
your clutch went bad, need to replace it.
Posted on Nov 26, 2008
SOURCE: changing a clutch on a 1959 ford 601 workmaster tractor
A FRIEND OF MINE HAS A 601 WORKMASTER AND IT IS LEAKING THE TRANSMISSION FLUID INTO THE CLUTCH HOUSING IS THEIR A SEAL OR GASKET TO REPLACE?
Posted on Mar 24, 2009
wilsodfarm
  • 986 Answers
SOURCE: hydraulic problem
Check your hydro preasures,pump could be going out,also could be in your relieve valve which will be cheaper,hope that is your problem because of the cost,Sound like you know alot about it, and trust you have a high mechancal ability,I have a hunch it could be in you valve, hope this helps,
Posted on Sep 02, 2009
  • 4088 Answers
SOURCE: Clutch fails to dis-engage clutch. 1986 F250 3/4ton 7.5 2wd
Make sure the slave cylinder body is attached firmly, then bleed the air out of the hydraulics--similar to bleeding brake lines. Watch the clutch mechanics while someone operates the clutch, (engine off) you should see definite movement. If you get movement and no clutch action, you may have to reappraise your clutch installation. Hope this helps!
Posted on Dec 19, 2009
Testimonial: "Thank you for your expertise, I crawl back under that Truck and follow your advice! Thanks again."
SOURCE: I have a Ford 8n with a new battery, solenoid and
Clean all the connections where the solenoid bolts to the starter. They are copper. Make them shine.
Posted on Sep 12, 2010
Why can't hydraulics on tractor lift bucket and slasher?
Filters maybe plugged or need more hyd. oil
Jan 31, 2016 | Garden
Does the pto have anything to do with the lift on a tractor?
Sometime around 1950 Ford tractors started using "live PTO". Prior to that the power lift for equipment required that the PTO be on and running (turned on by a lever on left side of chassis below the driver's seat). So 'yes' the older tractors (many in use today) require the PTO to be running in order for the lift arms to lift equipment. I find this very annoying when trying to run a mower, especially when the hydraulics don't hold very well.
Jun 27, 2014 | Ford 8N Tractor
1986 530 international loarder
Did you check oil level in hyd resivor it might be low also check fuses.
Nov 19, 2013 | Motorcycles
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
When engaging PTO it takes a few seconds before engaging bought the tractor new have changed hyd filters regulary. Any suggestions?
hydraulic filters wont help since pto is self contained unit first of all check pto lockup pressure my best guess is that clutches are probably getting worn
Oct 11, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Lift system isnt working and pto shaft dusnt rotate when activated
The pump may be bad or need bleeding out.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 17, 2010 | Ford Tractor Grill 2600 3600 4600 5600...
Hydraulic lift pump not lifting how to replace pump on a L245 kubota trctor
I have a Ford 1700 and the first time this happened I assumed it needed the oil changed (DID NOT read the manual). After changing the hydraulic oil for about $50... it ran no better. Read the manual. Bought the hidden oil filter. Bought new oil. Problem solved. The filter on this tractor sits in the bottom of the rear end housing and collect ever piece of junk. Good! But a pain to change the filter.
Nov 12, 2009 | Garden
Ford Tractor Grill 2600 3600 4600 5600 6600 7600 Logo
536 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
