Question about Toto Home
I have a SANA Gloss Toto toilet, recently the tank feels very slowly, this is a change, there are not leaks
  • 33 Answers
Fill valve may be clogged..
shut off water supply, and inspect (by removal if necessary) the valve and valve body that the water supply line goes into ( the float is attached to it by a (usually) metal arm.
clean clog or replace as necessary..
Posted on Aug 02, 2010
Which toilet is best?
I replaced the 2nd floor toilet in my house several years ago. It has all the features you require, except the 17" tank width. If you can fit a 20" tank ( actually 19 3/4") then the brand to buy is Toto. The quality is unsurpassed.
The (included) *seat* height is 16 1/8". GPF is 1.6, but the flush is amazingly powerful. I opted for the special self cleaning coating they call "Sana Gloss". Nothing sticks to it, it doesn't stain, and I've never had to use a toilet brush nor bowl cleaner on it the whole time I've owned it.
I bought mine from an online distributor. Just Google "Toto". I haven't checked recently, but they may have a narrow tank model. Mine has the extended bowl.
Apr 15, 2014 | Home
I have a toto duel Max toilet and the water leaks out of the bowl slowly. By the end of the day, I will have no water. Please help
Check flushing mechanism at the bottom of tank to check if it vopens and closes securely. and nothing blocks it.
Jul 27, 2013 | Toto Aquia II Dual Flush Toilet
Leaking from water tank
Is the water leaking from the tank onto the floor or at the water valve located where it comes in from the wall.
Feb 08, 2013 | Toto Toilet - Elongated Bowl, Dual Max -...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Love our new Toto Drake II double cyclone toilets with sani gloss finish. However the trip lever handles are already getting loose on both toilets... what would cause this-- and what is the...
dalbritton-
The handles are fixed to the tank body with a hex nut on the back (inside of the tank. They may not have been tightened properly from the factory. Tighten a bit with a wrench and you're good to go!
Regards,
DIYpro
Jun 08, 2011 | Toto Trip Lever For St774S Toilet Handles
Toilet fills up after flushing but water seeps out slowly from the top of the hardware. and when the water tank is full you have to lift the floater up manually in order for the water to stop flowing
I would change fill valve. You can use a simple valve such as a Fluidmaster 400A and change it youself if you feel comfortable doing it yourself,just follow insruction on box. Thanks
Nov 11, 2010 | Toto Promenade, 1.6 GPF, Elongated...
TOTO DRAKE flushes then the tank fills, stops, then slowley leaks and the water just runs on and on at a trickle pace down the overflow spout.
The rubber stopper that is inside the back of the tank is allowing water to get by do to:
(1.) Be wore out- must be replaced with a new one.
(2.) The chain that is connected to the flush handle needs to be adjusted. However, if it has not been messed with recently, then it will be the (1.)
Jim
Sep 13, 2010 | Toto Drake ADA Compliant Toilet with...
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
Home Logo
81 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
