Question about Dryers
I have a Whirlpool Duet Dryer. It turns on sensor light is on but will not run.
  • Dryers Master
  • 8,220 Answers
Your thermal limit is located hereI have a Whirlpool Duet - 6fe0fd9.jpg1006c0d.jpg
To get to it unplug the machine. Remove the top. Push in on the release tabs on the inside of the control and remove it. Unplug the control quick connect and set it to the side. Get the brace off. Get the control board panel out yer way. Open the door and remove the screws. Take the bottom panel off and the front panel then the drum out. Give it a good hoovering all over and replace the thermal fuse.
DUET DRYER MANUAL
Wanna see a video? This video shows how to replace a thermister. Next to it is that thare thermal fuse.
Rate it or hate it: ece6c0d.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2010
Whirlpool Duet dryer time skips mins.
clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
My whirlpool duet dryer will not start , lights come on but will not start none of the buttons work
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
My 5 yo whirlpool duet dryer just stopped. had run perfectly this morning. now, the power light won't come on. it is plugged in, free from lint, and tub spins freely. any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Sensor light on and beeping - dryer will not start - unplugged for 30 minutes - did not help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Have a Whirlpool AWZ3413 tumble dryer that will only run for a few minutes before the filter light goes on and the heat stops. The filter isn't clogged, but if I scrape off the tiny amount of fluff...
Here are more possible routes:
Duet Dryer Moisture Sensor Bar part WP3387223 How To Replace (See the KENMORE note below)... You MAY want to try cleaning the Sensor with a Q-Tip and alcohol! Not too much though... just a dab.
more from the Internet...
"This is most likely due to the vent being clogged between the back of the dryer and where ever it exits the house! This accounts for the light and the long drying times. A dryer not only relies on heat but also air flow to dry. if air flow is restricted, drying times get much longer since the moist air can not exit the dryer."
whirlpool awz3413 filter light keeps coming on even though
Here is a VIDEO for a similar KENMORE (Whirlpool). IF you suspect the SENSOR is bad and HOW to replace it:
Whirlpool Kenmore Duet HE3 Gas Dryer Moisture Sensor Bar 3387223
Be SURE and read the Comments below this VIDEO for more help!
Anthony
Dec 20, 2017 | Whirlpool Dryers
"Control Locked" light is lit and dryer won't run.
turn the lock off by holding the button down for 10 seconds
Apr 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
258 people viewed this question
Top Dryers Experts
Marvin
Marvin
