Question about HP Office Equipment & Supplies
Prints only 1/2 of page, just put new toner in and took out and put another new toner in.
  • 52 Answers
Check to see if output rollers and fuser moving what model of printer
Posted on Jul 29, 2010
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    BROTHER-MFC7430 Toner life end
    actually, you dont' really need to replace your drum, your drum actually is good for 5-6 years.
    you just need to clean up the drum with duster and put that back into the machine.
    when reset the drum, you just need to open the front cover and press Clear buttom then 1.
    after that the whole thing will be reset and ready to go for it.
    Dec 27, 2010 | Brother MFC-7340 All-In-One Laser Printer
    I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
    Run the 1/2 print test.
    Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
    Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
    Dec 19, 2010 | HP Office Equipment & Supplies
    Fairly new toner and display reads "Install black cardtricge"
    I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
    1. removed the black cartrige.
    2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
    3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
    4. I then put the black cartrige back in the the printer and restarted the printer.
    5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
    Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
    I replaced the toner cart. and now it is only printing 1/2 page
    Wrong Driver for your printer. Go to site and get an update
    Feb 27, 2009 | Lexmark E120n Laser Printer
    Hey m8
    • Buxie, first off you have voided your warrenty, secondly
    • If marks repeatedly appear on the printed side of the
      page at even intervals:
      • Clean the inside of the printer. See “Cleaning the
      Inside of the Printer” on page 5.7. After cleaning
      the inside of the printer, if you still have the same
      problems, install a new toner cartridge of the
      problem color. See “Replacing Toner Cartridges” on
      page 5.3.
      • Parts of the printer may have toner on them. If the
      defects occur on the back of the page, the problem
      will likely correct itself after a few more pages.
      • The fusing assembly may be damaged. Contact a
      service representative.
    • If horizontally aligned color or black streaks or
      smears appear:
      • A toner cartridge may be installed improperly.
      Remove the toner cartridge and reinsert.
      • A toner cartridge may be defective. Install a new
      toner cartridge.
      • If the problem persists, the printer may require
      repair. Contact a service representative.
    • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
    May 20, 2008 | Samsung CLP 300 Laser Printer
    Laser printer problem
    For starters aftermarket cartridges are just not like the new ones from Dell. I quit using aftermarket ones long ago to save these headaches, with Dell you can get on Dell Chat and they will gladly help with issues like this. Try that with "Bob's Printer Cartridge and Music Rental" you won't get anywhere.
    Mar 13, 2008 | Dell 3100cn Laser Printer
    Out of toner........ but not really.....
    Print a Supplies Status page to see the actual pages printed...
    To print the Supplies Status page from the printer, on the printer control panel, select
    Reports Menu, Supplies Status, and then Print Supplies Status page.
    If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
    Hope this helps.
    Mar 07, 2008 | HP Color LaserJet 2600n Printer
    Toner low, tone life end
    There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
    Jan 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
    mukhtar21 shaikh
    mukhtar21 shaikh
