Question about Refrigerators
My new frigidaire rolls forward when opening the door it has the adj rollers but no feet.
Frigidaire ref. model fghc2331pffa rollers don't roll
Make sure that the refrigerator's feet are not making contact with floor. If they are, they will negate the rollers!
They screw in to recede.
Sep 19, 2017 | Frigidaire Refrigerators
Tip
Tricks with the Roller wheel...
While on a url address, click the wheel without rolling it and it will open the new website automatically in a new tab, window.
To zoom any picture or window, hold down the Control key with your left pinky and roll the wheel forward or backwards.
on Dec 31, 2009 | Computers & Internet
Need to rebalance refrigerator
Hi Susan ! If you look under the fridge at the front you can see the front two feet at either side. Both of these feet are adjustable, a collar on a threaded PVC foot with normally a straight roller at the bottom. You will need to roll the fridge out a little and using some one to help tilt the fridge back a little to get your hand on to the collar. Some are able to be turned with just your fingers with out tilting the fridge but it is easier with the weight off them. If door self closes the fridge is tilting back, tilting forward the door will stay open. Now by loosening or typically threading the collar anti-clockwise the foot height will reduce and the fridge will become more level and the door will close slower. As you get it just right to your personal liking just wiggle the fridge a little and make sure all the feet are touching the ground. The use of a level and patience can have you set it up just right for you.
I hope this helps as myself being a fridgy like my fridge door a certain way, customers like sometimes know how they like it and there is the way the fridge is ideally installed.
Mar 20, 2014 | GE GSS22JET Side by Side Refrigerator
How do i load new paper?
open door, place paper in cradle and pull a tail of paper from the roll with this portion facing down, then close the door, no need to feed it though any rollers etc.
pulls the paper from the bottom so the side that is loose goes towards bottom.
if you hold it in hand, the paper that comes from bottom of roll goes in cradle pulling 3 inch paper out of roll and closing door on the paper. tear off
Mar 12, 2014 | VeriFone VX510
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Hi I just bought a whirlpool refrigerator and it rolls forward on opening the doors. Is there anyway to prevent this? It is on a wooden floor, Thank You Model NumberED5FVGXWS
At the bottom front of the refrigerator there are two feet. One on the left and one on the right. These need to be screwed down untill they touch the floor. Once they are touching the floor they should act as anchors stopping the fridge from moving
Mar 31, 2011 | Whirlpool Refrigerators
I have a combined Bosch fridge/freezer unit. It is the frost free type of freezer. Lately, the bottom unit (the freezer), the door sometimes seems to have no pressure behind it and will not stay shut.
use a level to make sure unit is not tipping forward. adjust 2 front feet to tip slighly backward door will then close itself from about 6 inches......poss feet have sunk into floor covering.....
Feb 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Power window tips forward and binds
one or more of your rollers in the regulator are broken.needs new regulator or roller kits.
Nov 08, 2008 | 2000 Chevrolet Tracker
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Side-by-Side Built in
Adjust bolts until rollers are touching floor. Grab the unit low and on the outsides of both doors. It should then roll out fairly easily.
Sep 26, 2007 | Refrigerators
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
