Question about Microwave Ovens
My lg solardome model mp9483sl has blown its lamp and now the turntable is not working either
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Posted on Dec 21, 2008
stewbison
  • 577 Answers
SOURCE: why dosn't the lamp of
Bulb is burn out. GB...stewbison
Posted on Aug 22, 2011
Replace door on lg solardom microwave
You need to be carefull. You need a tester to use to check aroud the door after installing door. You should have a qualified tech. check it.
Jul 09, 2016 | LG Microwave Ovens
LG Solardom MP-9483SLA bought 2 yrs ago,
Idont understand the problem pls write the main problem
Sep 15, 2014 | Microwave Ovens
I have an LG solardom microwave and when I want to heat a small amount of liquid, it sparks and the base(not the turntable) of the microwave gets hot.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
Nov 24, 2013 | LG Microwave Ovens
Lg solardom oven innerdoor replacement
go to www.repairclinic.com or www.appliancepartspros.com and buy it
GOD BLESS YOU
Jul 16, 2012 | Microwave Ovens
Solardom microwave won't stop turning
quite possibly the door switch has failed . take it in to a repair shop , if you can find one locally
Oct 17, 2017 | LG Microwave Ovens
I would like to know if it is possible to change a light bulb in the LG solardom Microwave without calling an electrician?
If your owner's manual doesn't cover lamp replacement, you will have to take the oven apart to do it.
If you don't have your manual, you should be able to download it from here.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's here.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Otherwise, please reply back with your model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | LG Microwave Ovens
Non rotating lg turntable fixit try failure
Looks this model's turntable support has a coupler shaft built-in which is supposed to go down into the turntable motor hole and make contact with the turntable shaft. Is that right in your case?
So I would wonder if the turntable support has gotten bent due to heat. That's common on some models.
When you take it out and look at it from the side, are the legs straight and perpendicular to the shaft or are they bent down?
On some models, you can heat them over a stove flame, then put them on a flat surface with a weight to old them in position while they cool.
Otherwise, you'll need a new turntable support. LG / Goldstar calls this a "rotating ring".
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
May 12, 2008 | LG LRM1250 Microwave Oven
Lg lrm 1250
Microwave Ovens Logo
227 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
