Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Hi,my bosch f/f is freezing in the veg box and has a lot of ice under the last box in the freezer comp.What is the problem please?
In the back of your fridge you should see a hosepipe connected from the freezer's defrost water drain to the evaporating tray usually located on top of the compressor. The drain is blocked, hence you get ice on the bottom of freezer. The easiest way to clean it is to pull the hose pipe off the fridge outlet and clean the drain upwards with a piece of soft wire or electric cord or something similar. On my fridge (Bosch) I found the drain clogged with a kind of jelly like stuff. The other way to the drain is by removing back panel inside the freezer compartment but be careful, I sort of ripped mine off and broke plastic plugs on which it was fixed. Make sure you know what you doing.
Cheers Karel
Posted on Aug 24, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
The bottom of my fridge is frozen alonge with the fridge food
Hi sir
it bis thgermostat problem,(heating element),,,so the heating is not done properly by thermostat,,so u should check iot,,,
thank u,,,please rate it,.,,,
Jun 30, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Cold box at the top of the fridge
This box is the evaporator which provide cooling for the whole fridge. They will only freeze things solid that are easy to freeze. Don't count on it being like the normal freezer.
Nov 12, 2007 | LG GC-151SA Compact Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
222 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
