Question about Toro Garden
Toro 51992 weedwacker -Won't start - Fuel Filter line
Toro 51992 weedwacker won't start. The gas line with the fuel filter on it was just laying inside the gas tank. Took the gas tank off, so I could check the lines. The lines seem ok. Now I'm trying to figure out were the line with the fuel filter hooks back too. There's a rubber seal with two holes in it...one for the primer bulb and a second for the ??main line. Does the fuel filter line hook up to the primer bulb, or the main line?
5 Suggested Answers
pippall
  • 1486 Answers
SOURCE: got a homelite ut 15039a (weedwacker with blade st 185)
You have the rong fuel tank for that model.Thats the return pipe its comming from so you can drill a hole if youwant but make sure its sealed properly.
Posted on Jul 12, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Posted on Feb 25, 2010
Testimonial: "Yes, was almost exactly what I needed. Did have to search to find which port on the carburetor was the inlet an the other the outlet."
  • 1746 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
canwoodjc
  • 3301 Answers
SOURCE: I have a Craftsman Weedwacker
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Posted on Jul 24, 2011
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
How far in the gas tank does a toro trimmer fuel line need to go -- I assume not very far and not as far down as the filtered gas line, correct?
The gas line with the weighted fuel filter on it should lay across the bottom of it (somewhere near the opposite side) and the purge/return line only needs to enter the fuel tank 1/2" to3/4" to work.
Sep 11, 2011 | Toro Electric Trimmer
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
Weedwacker won't stay running
replace the fuel lines and check that the filter in the fuel tank( its on the end of the intake fuel hose) is clean. If there is an air leak somewhere in the old lines it will cause the trimmer not to get enough gas.Then clean the carburetor with carb cleaner- take the carb off by removing the air filter first then undo the two nuts holding on the carb and take off accelerator cable remembering which hole it came from. spray the hole carb with the cleaner on the inside and outside then soak it in the cleaner trying to get any dirt out. put it back together and it should start...if not you might need a new diaphragm in the carb.
Jun 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Weedwacker won't start
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
May 31, 2010 | Craftsman 25cc Gas Line Trimmer
Garden Logo
478 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
