Question about Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
The front nose cone fell apart how does it go back together. Thanks don
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: I took the front end of my bosch apart and I can't
go to eReplacementParts.com : Power Tool Parts and Tool Repairthey had parts diagrams that are helpful.
thumbs back!
Posted on Oct 26, 2010
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
Pt 3406107 fell apart. I need to know how it is wired to put it back together. It is the door switch that cuts off the dryer power when the door is opened. There is a small spring and a free standing...
if it fell apart Just get a new one and use the connector supplied with it ,, Once they give way they possess a danger better safe than sorry and the part isn't that expensive, heres the part for 16.00 and change !! http://www.partselect.com/PS346704-Whirlpool-3406107-Door-Switch.htm?inventory=346704&SourceCode=6
May 24, 2011 | Maytag Dryers
Have removed two bolts and wire but starter will not budge, what am i missing
there is a nose cone bracket that is mounted to one of the starter motor bolts and the other end is atchaced to the side of the engine block.it can be a pain to remove it but it is nessery of you don't reinstall it you will brake the nose cone on the new starter.
Apr 17, 2011 | 1992 Buick Skylark
I have a Marvin 1210 window fan with a rotating front grill. The grill has come unscrewed from the fan motor shaft and I can not see how to take the front nose cone apart to get to the screw so I can...
mcdevito75 here, hello ken, I did a fast search and I think www. shop.com can help you out with Marvin air fans, I didn"t find anything on Marvin Air Fans itself. Now about the nose cone covering the nut holding the blade to the fan shaft, most of these nose covers are press fit, see if you can gently pry that nose cover off with a small screwdriver.
Jul 23, 2010 | Marvin 1210 Floor / Box Fan
WE HAVE A HEATER THAT HAS STRONG FUMES WHEN RUNNING. THE COILED FOAM FILTER IN THE BACK FELL APART. DOES THIS HAVE ANYTHING TO DO WITH IT?
It sounds like you need to increase the air mixture. there is an adjustment screw in the back next to the foam filter (which you can get a new one at Ace Hardware). Dial the screw in 1/4 turn at a time until the nose cone turns about 90% red/orange and you should notice a great reduction in the fumes and a greater heat output.
Jan 07, 2010 | Reddy R70ET Utility Heater
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
Top Bosch Hammering Experts
John Trevino
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
