Question about Video Game Consoles & Games
After my xbox live has been playing for about 20 minuits the game just blanks out and the green light around the eject button begins to blink orange and continues until u unplug the xbox.
  • 84 Answers
You have the RROD also known as the red ring of death, if you still have the warranty, you can send your 360 to microsoft for a free fix.
If you don't, visit here on how to fix it yourself
http://www.instructables.com/id/Fix-the-Red-Ring-of-Deathwithout-towels/
Posted on Jul 28, 2010
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
Jan 27, 2011 | Nintendo Wii Console
My sons xbox 360 wont turn on
Check the power supply unit, if the light is green or orange and still doesn't power on, try pressing the eject button on the xbox it should turn on if you do, if the power supply is red then you should contact xbox support.
Oct 21, 2010 | Microsoft Xbox 360 Console
My x box will play cd's and dvd's but not games. do you know what i can do to fix that. when i put in a game it says to put disc in an x box 360 console.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game. Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Mar 10, 2010 | Buck Legendary: The Box for Xbox 360
Game stuck/blinking red light
i was playing mw2 yesterday and bam (red light of death) ill prob have to send it to sony but i got the game out follow these steps. 1. turn off at the back. 2. hold your finger on the eject button. 3. turn on again at the back while holding the eject button for a few seconds 4.your playstation should start up and your game should be ejected
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
I cant get my game to eject from my PS3
i get same problem, this should work:
turn the main switch off at the back, then hold the eject button then turn on the switch while still holding the eject button. fan should go at max speed then it should die down after 20 secs.
Sep 12, 2009 | Sony Playstation 3 (PS3) Console
Original xbox continous blinking green light, no eject & loading
sounds like a bad cable between the console and the TV, the XBOX is notorious for having issues if the cable isn't the correct one (a Microsoft one) or damaged.
the flash green with nothing else happening can be a failed bios.. coma console variant. It's possible to fix it with a chip, but uneconomic considering the price of a working box these days. It can also be a failed ide controller or bad ram..whatever, it's normally a scrapper with these symptoms unless you have a good junkbox...
If you have an xbox that fell it's always worth changing over the dvd drives, as they can cause weird faults as well, (as mentioned above re: unknown disks) as the green flashing is the usual "loading disk" message.
Sep 08, 2009 | Microsoft Xbox Console
3 ROD but power supply constant orange,no green
When someone say that his/her Xbox is having 3 red lightsproblem, It means it needs to be repaired. If you are using Cooler thanit is not a cure but a prevention. You could have used cooler beforeacutally having the problem just to prevent your Xbox. But now you willhave to either get it repaired from Microsoft (in case your Xbox'swarranty is not expired, but one thing to note is that you will have towait for at least 3-4 weeks to get back your Xbox) or you can Fix yourXbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Oct 23, 2008 | Microsoft Xbox 360 Console
Xbox not reading game
I don't know if this will help anyone, but I have tried a variety of things that occasionally have worked. Eject disk and pop it back in and then restart 360. Sometimes may require doing this a couple of times. If that doesn't work, try unplugging that thing in back with the orange light and replug it. Or simply, as it worked for my brother, just turn the 360 off and unplug the orange light thingy and don't play again until maybe a week or month, etc. He unplugged it for about 3 weeks and then it worked perfectly again. Sometimes the 360 just needs a little break. Even though this may be impossible for most to leave it alone for even a day, but its either you or your 360. make it live again!
Jan 06, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
