I have accidently uninstalled the "other devices" ethernet controller and unable to connect to my modem and can't find the drivers for a e-machine T3522
    Brigadier General:
  • 6,966 Answers
You could try to auto install. If that would not work, try manual instal and when Windows asks for the drivers' location pls type/point to C:\Windows\inf\, additionally some are also located in C:\Windows\Stsem32\ and/or C:\Windows\Stsem32\drivers\
Alternately, you can try on a 2nd PC downloading appropriate drivers, save them on a flashdrive and copy/install in your e-machine T3522. Incidentally, the e-machine T3522 uses an Intel D915GUX with built-in Ethernet controller/LAN/NIC. Drivers may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 24, 2008
Unable to conect to internet this is on going problem
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
or you could click start control panel admiistation tools computer management device manager look for network adapters it might have a red X or yellow question exclamation ? ! mark if you see either of these right click to update driver if your computer came with a motherboard disk the drivers could be on it
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 21, 2011 | Computers & Internet
Hi, when i tried to connect to the internet, it shows "OS error,may be the modem on your remote computer is out of version please solve my problem
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Jun 11, 2011 | Dell 210W Optiplex GX270 NPS-210 AB Power...
I ALWAYS GET AN ERROR UPON USING THE ROUTER TO MY SMARTBRO BROADBAND INTERNET.
because you have not stated what the error code is unable to point you
if you are referring to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
also you might check
check the leads from the modem/router whether usb ethernet make sure they are not bad/faulty and have secure connection
hope this helps
Apr 28, 2011 | Computers & Internet
Unable to use LAN
if you are reffering to your internet connection
hope this helps
Apr 12, 2011 | Computers & Internet
I need the ethernet controller driver...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Dec 02, 2010 | Intel D915PLWD Motherboard
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Ethernet driver not found on S50 pc
hope this helps
Nov 28, 2010 | IBM ThinkCentre S50 PC Desktop
Need ethernet controller driver so i can get on the internet
hope this helps
Nov 22, 2010 | ASUS Eee PC 900HD Netbook
No ethernet drivers
if your internet modem has an ethernet connection the drivers should be on the disk provided by the internet provider control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Oct 23, 2010 | Computers & Internet
Computers & Internet Logo
289 people viewed this question
David Payne
David Payne
