Question about Dell Inspiron 1501 Notebook
2000-0146 error and oxc0000ed
I have a Dell 1525 running on Windows 7. I had to re-boot my system because of the following error codes.
Oxc0000ed Windows Boot Manager - regarding a device connected to my computer. Checked all connections, and removed all devices, etc and. re-booted. Cannot get rid of error message or get to desktop.
Ran diagnostics and got error 2000-0146. Any suggestions as to where I should go from here? I have googled errors - but it is too technical for me. Possible hard drive errors?
  • 3,940 Answers
Hard drive failure. If the system is under warranty, contact Dell for a replacement drive. If not under warranty, you can get a new drive here:
www.newegg.com
Posted on Jul 28, 2010
How to fix error code 2000-0142
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Jun 18, 2012 | Dell Inspiron 1525 Laptop
DELL 5150 hard drive error 7
Error code 7 means that your hard disk drive failed and is defective. As for reloading windows XP, I wouldn't. It's not supported by Microsoft any more. I would load Win 7 after replaceing the drive.
Feb 20, 2012 | Dell Dimension Computers & Internet
Stuck in start up repair 1525
Try the next oldest restore point until the issue is resolved. Any software installed after the selected restore point needs to be reinstalled.
If system restore still doesn't work, run the "Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers", you may click the link below to go directly to the support site, it contains instructions in running PSA Diagnostics and Error Code List with possible fixes.
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#Issue2
Hope this helps.
Nov 19, 2011 | Dell Inspiron 1525 Laptop
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
I have dell inspiron 1525.I am from India. I have two problems. First I have a sim card slot in my laptop and ai don't know how to activate it. My other problem is serious one. My laptop unexpectedly...
Dell has a series of tests for a system's hardware called the PSA+ Diagnostics. You can run these tests by performing one of the following actions:
  • Hold down the key while pressing the power button.
  • Turn on the system, press at the initial Dell™ logo screen, and select Diagnostics from the boot menu.
  • Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message Diagnostic boot selected displays. The system then launches the PSA+ Diagnostics.
  • As for the laptop shutting down, that usually indicates your CPU (Central Processing Chip) is overheating. This is caused by dust or defective CPU fan or heat-sink.
Jun 10, 2011 | Dell Inspiron 1525 Laptop
I run Dell Inspiron 1525 , it boots well , but can't open any windows program,
Hello.
You probably have an operating system problem with corrupted files.
Boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
Hope this helps.
May 09, 2011 | Dell Inspiron 1525 Notebook
I did a diagnostic test on a dell inspiron 1525 and everything passed except the hard drive with error code 0142, what does this mean and can it be fixed, thanks.
Based on
Dell Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers - KB Article - 30042,
it is a Hard Drive failure, and you need to replace the Hard Drive.
I suggest to try reinstall windows first before you replace the Hard Drive.
Hope it helps you.
Apr 17, 2011 | Dell Inspiron 1525 Laptop
Inspiron 1525 Error Code 4600:021E msg: Processor
There are several Reasons.
  1. Your Processor heated up more than the expected limit. Often caused by a trouble with Heat-Sink(and or the Copper tunnel if have one inside), Short Circuit. You have to check the Processor and its Socket.
  2. CPU fan is not functioning: You have to check whether the fan works properly (with a good speed - rpm).
  3. Your Sensor has a fault. You have to check the Sensor.
Jun 15, 2010 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Error 2000-0142
Hi there!
The error code you have there means that the Drive Self Test failed. You can try to power down computer, disconnect and reconnect hard drive from the system board. Run the diagnostics , if no error occurs then it's a cable/connector issue, if it failed with the same error, replace you hard drive,
Hope this helps!
May 30, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1501 Notebook Logo
349 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
